Any clutch recommendations for mt82?
aedfam
Sanger, ca
Aed
Ford Mustang 2017 GT
Hey fellas,
I'm looking for some input on what clutch I should get for my set up. I'm running a supercharger (high 800rwhp, but do plan on going for around 900-950 eventually) with a MT82.
What clutch kit would you recommend for NY set up? I'm thinking of pulling the trigger on a mantic clutch as I'm told that's the only reliable clutch for mt82. I was wondering tho has anyone ran or had any trouble with the Mcleod clutch? There's about a $1k difference between the two so I'm wondering if what people say about the Mcleod clutches are true (that they constantly break MT82s).
Also I'm eventually going to go for a stage 3 mt82 from calimer if that helps.
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
I run a McLeod RXT twin disc with a lightweight flywheel. Apparently it's rated for 1200hp. I don't plan on going past 480whp. It's obviously heavier than stock but I use a lighter clutch spring from Steeda. It's pretty awesome. The bite is great and you can shift as fast as you're able and with the lighter flywheel, the rpms drop really quick so the engine revs a little happier.
m3incorp
Georgia/Colorado
James
OP have you researched the Lethal Performance clutches? I think they run in the price range of the McLeods.
aedfam
aedfam
Sanger, ca
Aed
Aren't they basically the same as a Mcleod clutch? For some reason I thought the LP clutch was produced by, or in collaboration with McLeod, which brings me back the same dilemma of not having any feedback on how they actually run. I was actually thinking of calling LP and getting input from them but I'm wary of asking for recommendations from a sales company as their job is to sell you a product. I'm not saying they can't be helpful tho but I would also like to hear from you guys, the consumers, what actually works and doesn't work.
m3incorp
Georgia/Colorado
James
There are forum topics on here from people that had both the McLeod and Lethal. Supposedly the Kelvar in the Lethal clutch makes a huge difference.
aedfam
aedfam
Sanger, ca
Aed
I'm going to look that up.
Andrew@Lethal
West Palm Beach Florida
Andrew
Hey fellas,
We offer the best clutches for the MT-82 transmission. It's our Lethal LPX and LPX-HD which utilize Kevlar disks. Please give us a call to discuss your goals and recommend the appropriate clutch for your application. www.lethalperformance.com
Djervin
York, PA
Dustin
2015 Mustang GT
I ran the RXT and liked it. I now run the LPX HD and love it. Keep in mind Calimer is going to almost insist you run a 26 spline input shaft on their Stage 3 (which I'm now running). Not sure when you're planning on the built trans but you might want to consider the input shaft spline count and diameter when ordering the clutch.
xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
Any issues with the Kevlar clutch glazing?
aedfam
aedfam
Sanger, ca
Aed
I was looking into your clutch and it seems as the HD is rated for 1000HP. Is that 1000HP to the crank or to the wheels?
Andrew@Lethal
Andrew
Sweet. I'm going to be pulling the trigger on it in that case. That was the only concern I had whether or not it was rated to the wheels. 😁
Give us a call before you order, we might have a promotion going on. Ask to speak to me "Andrew". 1.877.253.8425
Bear380spin
Monterey
Jonathan
2021 5.0 manual
Hello I plan on making around 550whp is the mcLeod rst good.
