ArcsandSparks
Probably wrenching
Alrighty folks, before I take the car to Ford let's see if anyone can point me in the correct direction. I've included as much info as I could think of- as well as my own hypothesis.
I'm thinking the OEM clutch let go and is causing the noise- if this is true, how does everyone feel about the McLeod RST?
I'm a little bit too deaf to hear if it's coming from a catalytic converter, but I know that oem cats have been known to fail; I just couldn't imagine it would happen this quickly. Because of this, I'm avoiding driving the vehicle and have an appointment with the closest Ford dealer that I trust (less than 4 miles away).
Symptoms:
Metal on metal whirring noise coming from the transmission/bellhousing area. Increases in volume + rate with engine RPM.
If I turn the engine off with the vehicle moving and the transmission in neutral, the noise goes away.
If I turn the engine off with the vehicle moving and the transmission in gear with the clutch depressed, the noise goes away.
The noise is directly correlated with engine RPM, and the transmission seems to be working as intended. There have been no changes in clutch pedal feel or shifter feel/operation- this noise is the only symptom.
Background:
I'm not sure when the noise started- it was either after a 2-3 upshift or when I got back into the throttle after shifting into 3rd.
The 2-3 upshift was clean- I have an MGW shifter and haven't missed a shift since I installed it.
Vehicle Mods:
Roush S/C, MGW shifter, Steeda braided clutch line, x-pipe, and various suspension modifications.
Symptoms:
Background:
Vehicle Mods:
