GWraith
I have a 2021 Mustang GT 5.0L Roushcharged base model. It came with the 4in sync 3 stereo.
I have upgraded the software on the APIM to 8" and added a touch screen and toggles.
That all works fine,
The issue I'm having is I added an aftermarket:
4-Channel AMP JBL Stadium 4
plugnplaykits.com 4 channel 17' harness
PRV DSP
10" Pioneer Loaded Sub Enclosure
5 FARAD cap
All 6 speaker replacements with PowerBass OEM
I originally set it up to use hi-line out but it had way too much noise on audio wires when the sound was off. I switched it over to lineout no EQ using Forscan and set my amp and DSP to it as well.
The noise stopped at +0 gain but only when I have left and right channels bonded for each output on the DSP.
My Pioneer-loaded sub enclosure had to be used through a Ground Loop Isolator or I'd get alternator whine really bad.
My wiring setup is straight ground and a positive 4 gauge to the battery on the passenger side. 3-way splitter terminal so everything is wired in parallel. The audio wires to the amp and from the amp are run on the driver's side. Originally I had the static issue as well when all of it was on the passenger side so I rerouted the speakers "out & in" to the driver side and the noise remained unchanged which is why I stopped using Hi-EQ output and changed to line level, the hiss was non-existent at 0 Gain.
Since I have a Roush supercharger the tune has disabled active battery charging so when the car is on its pushes 14.3V - 15V at all times. The alternator is 175amp stock.
The battery is in good health, stock battery, 12.7V
I have no power issue and the cap is simply there for voltage stability.
I have no static on my 2 channels out to the sub but I also have my LPF set at 145Hz.
On my DSP I had to combine FL/RL (A)and FR/RR(B) to bring the 4 channels into 2 (A & B). Then they break back out to 4 after the DSP. If those 4 channels are all A+B I get no static at 0 gain but the gain noise slowly increases as I add gain. The gain will also be present depending on the EQ preset selected.
HPF is set on all 4 channels at 80Hz.
If I set Each channel according to the side of the car eg. Channel 1 (A) 2(B) 3(A) 4(B) I immediately get static with no audio even at 0 gain.
I plan to have the system mic tuned for accuracy but I need to solve with white noise/hiss issue.
My thought is that the Audio Control Module (ACM) is the source of the hiss but being a 2021 I cant source a new one to compare. I have a 2017 ACM sitting in the garage but using that throws codes and I haven't tried swapping it in just to test the audio since I put the system in.
The system gets plenty loud at my max of 22/30 ticks. Should I continue to chase this white noise issue? Is there an increase in fidelity or quality if I separate the left and right channels?
Before I had the DSP the hiss/white noise was more prevalent on the front than the back speakers eg. 2% gain on the front before I heard it while 15% gain on the back before I heard it.
I have not found any recent posts about putting any extra grounds on the ACM, the last one I found was like 2010. Our radios from what I understand do have a small-cap connected to them to help with the noise as a reference from the parts catalog.
https://parts.ford.com/shop/en/us/e...ts/capacitor-assy-radio-suppression-6501243-1
A new ACM from Ford cost almost $1K and didn't have the issue when it was stock so I'm assuming they wouldn't warranty it anyway.
https://parts.ford.com/shop/SearchD...pe=&beginIndex=&pageSize=12&pageNumber=1#list
Let me know if yall have any experience with this or have any suggestions. Thanks for the help!
To reference the pictures the output from the amp is in between the cap and the amp while the input is toward the driverside wall. The PRC DSP was added to the third slot for power on the splitter. So the cap and the DSP are sharing a power port whing should not matter as they are still in parallel. I don't have pics with the DSP installed but image it under the amp. As the DSP didn't bring the problem in I doubt it's the cause.
PRV DSP
5 FARAD cap
