Active exhaust tune
jimharrell
Oviedo, FL
Jim
2023 Mustang Mach 1 HP
I talked to Ford Performance a while back and I think they suggested to talk to Lund tuning as they had tuned a Bullitt they had to keep the driver mode stick between startups. Has anyone done something similar? Can it be done in Forscan?
Schwerin
Home
2019 Mustang
The only way I know of is to put the car in the setting you want, then pull the actuator from the back so it won't send a signal to close it again.
I believe FORscan can disable it but I'm not sure if that means it stays in the setting you leave it in when it was disabled, or if it just cant change position after restart.
Siege
2019 Mustang GT Convertible PP1, 2003 Marauder Trilogy S/C #250, 1992 Mustang 5.0 Notch
With HPTuners you can set the exhaust full open or tweak the tables for the different drive modes to fit whatever loudness you want.
jimharrell
jimharrell
Oviedo, FL
Jim
Will it go back to the default after an ingnition cycle?
