I have bone basic (tiny screen) multimedia system.https://www.wadeford.com/blogs/2562...ode-technology-feature-the-2019-ford-mustang/
Supposedly works on the 18 too, but I’ve never tried it!
Maybe simpler to put an on/off switch on the power wire to the valves, Put the system in track mode and turn the switch off and the valves stay open, Flip the switch on when you want to change modes.I wonder if you disconnect the actuator plug if it will default to valve open or valve closed.
That would most likely disable the active exhaust modes totally...not sure where it would default too though.I wonder if you disconnect the actuator plug if it will default to valve open or valve closed.
It definitely does, as well as disables all drive modes completelyThat would most likely disable the active exhaust modes totally...not sure where it would default too though.
Yes car will start in normal although the baffles are still completely open. If you switch off to refill gas or something for a short period of time it will stay in track or whichever mode you have it in. But after an extended period of off time it reverts to normalI have been saving track exhaust on my mymode but sometimes it will go back to normal? So the car is programmed not to start in track mode? That sucks if its true.
