A-pillar rattle
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
Hey guys, did a search but could find anything. Just the past couple days my gt pp has started making this rattling/buzzing sound that seems to be comig from the a-pilar. Anyone have au ideas?
PJE
Novi, Michigan
Peter
2015 Base Ecoboost Mustang - Ingot Silver
How high up does the sound appear to be coming from? My EB has an intermittent rattle from the light switch control, which makes it seem like it's coming from the base of the A pillar.
Jeffy_2010
Jeffy_2010
Missouri
Taylor
I seen others having the light switch rattle, I tried pushing against the dial but didn't seem to solve the issue. It's towards the base of the a-pillar next to the door it seems like
Quiksilver15
Houston
2015 Ingot Silver GT
I have something very similar that I have not been able to pin point, doesn't help that it is intermittent.
TheNameAndy
Las Vegas
2015 Ecoboost PP
I have the exact same problem as you. Rattles are coming from the passenger A-pillar, I know this because when I slightly press against the A-pillar while driving the rattle/buzz goes away, and when I take my hand away, the rattles come back instantly. I'm pretty sure something is loose, bolt or clip. I actually plan to take it apart, investigate and see if I can fix the problem myself.
Jeffy_2010
Jeffy_2010
Missouri
Taylor
Well I think my mustang was haunted from the factory cause I haven't heard that rattle in days knock on wood!
ib2loud
Oklahoma
Brad
2015 Ecoboost
I have a very loud and annoying rattle from the driver's side a-pillar. If I barely press, it will stop. I was thinking of taking it to the dealer to look at but wasn't sure if they'd even consider trying to fix it.
Elvis has a Mustang
Defiance Ohio
2015 Ecoboost Premium Convertible 50 Years Edition
It sounds like the clips that hold the trim on is not making the proper, tight connection. Could be bad clips or the holes in the metal A pillar could be at the top of the tolerance or maybe even be a tad out of tolerance. Make your dealer fix it.
TheNameAndy
Las Vegas
2015 Ecoboost PP
I tried to take the A Pillar off a couple of days ago. The top of the A Pillar was easy to pop off, but couldn't get the bottom to free up. I didn't want to break any plastic or clips holding it, so I popped everything back into place. Since then I havnt heard any rattles from the A Pillar.. it was probably a loose clip or something ..
ib2loud
Oklahoma
Brad
2015 Ecoboost
I'll give that a shot before talking to the dealer
