I realized that loctite is anaerobic and needs a primer to set. I see that professionals have what look to me to be pretty complex setups for using loctite to make it set.If 2 sheet-metal panels are creaking against each other, the best solution (if possible) is to squeeze something in-between, to act as a wedge. If not possible, that's when a liquid/semi-liquid type of sealer is needed, but unless they penetrate really well, it's not that effective. I'm going to order a Pioneer sub for my car, and when I install it, will do the right panel removal, and investigate. Also noticed removing the upper rear panel shouldn't be that hard, so might do that too, and kill that damn rattle once and for all . Thanks gang.
I was wondering the same thing... never heard of Loctite being used as an isolator or take the place of a proper weld...Can't see how a thread lock/sealer is going to do much in this case unless they tried to have it seep between the panels to create a membrane type of insulator.
<snip>
I think it must be a Loctite branded product, not just the thread locker. It wouldn't ever set up exposed to air. Maybe something like this:I was wondering the same thing... never heard of Loctite being used as an isolator or take the place of a proper weld...
Depending on how long it stays pliable, you might be able to squeeze or "spackle" some between the seam. Something that would expand to fill voids might also work.Interesting but I wonder how they got it between the panels.
@Thegipper can you post a photo of the repair please?
Thanks for posting these pics and detailed description of what you did - I think eventually we'll have isolated the actual cause of the rattle / squeak, or will have foamed/padded/glued every cavity of our cars... Mine is getting worse, so I'm going to have to dive back in when I get some free time. So much to do.Okay I have stopped the c-pillar/ rear passenger side rattle! Going strong for 2 days now. I have tried everything in the threads I could find on the issue from the control device in the trunk to spraying the gaps with expanding foam behind the c pillar cover, I installed sound deadening material in the entire trunk area and under the deck where the speakers are. I also used seam sealer on some of the panels in the trunk as discussed in some of the threads. Nothing worked, but Here's what stopped it for me.
I removed the passenger side rear trim panel, just the lower half, it's easily removable and comes out in one part. I bought sound deadening sheets off Amazon and applied to the entire area that's exposed behind the plastic trim panel that I removed. I also added felt and tessa tape to the metal clips. The foam on the back side of the panel was broken off on one other hold down points, I don't know if it broke when removing the panel or when being installed at the factory, but just be careful when removing it you don't bump it because the foam looks like it could break by just looking at it. I used automotive adhesive and hot glue to repair the foam. I also applied small felt tip pads on the perimeter of the foam panel that buts up to the sheet metal. Reinstalled and it's nice and quiet. Taking a 10 hour road trip to drive the tail of the Dragon next week, that will be the ultimate test to see if this fix holds up.
Haha. Seriously. The amount of troubleshooting we have done is legendary.It would have been nice if Ford put as much thought and effort into this as the owners in this thread have.
