venumous
How much boost? Ever narrow the problem?Lmao. He said longevity. I upped the boost when I went e85 and went boom.
Well e85 allows more boost and timing before knock or no knock. E85 alone adds power. So depending on his goals, more boost may not be needed.So that's the rule or the exception?
18psi @ 8K. 4 bent rods and broken oil ring on piston #2. No evidence of headgasket failure. I'm assuming I just overpowered the rods.How much boost? Ever narrow the problem?
Yea I knew I would be on borrowed time. Just hoped to make it till winter. Now i get to do build 2 in the Texas heat.18PSI at 8k and you wonder why the motor went? haha.
I think you'd be fine at 14ish psi on E85. How much timing are you currently running on pump?my goal is to not end up like j this year :lol:.
im guessing E85 to 7300 with maybe a few degrees more timing at same pulley would be just fine, if i swap to LTH or cat delete?
i was told i was locked to 16 degrees but im seeing 18 on half a can of torco at WOT. its in the log i posted in post 2.I think you'd be fine at 14ish psi on E85. How much timing are you currently running on pump?
Thanks Dick!my goal is to not end up like j this year :lol:.
?? not sure how you came to that solution?solution here is simple buy a boostworks twin turbo kit...............
Expect around 23 on E85. It'll be a big difference. There are a number of paxton guys running the 3.48 on E85, which is 14ish PSI. Not sure if they are daily driving it or not.i was told i was locked to 16 degrees but im seeing 18 on half a can of torco at WOT. its in the log i posted in post 2.
once i run a few tanks through the car ill re-datalog now that i have it ironed out. when i was at the track the datalog would go away after a few seconds and i couldnt activate it at the line. ive since done a FW update to resolve the issue.
i am serious, and dont call me shirley....Thanks Dick!
oooohhhhhh hmmm.Expect around 23 on E85. It'll be a big difference. There are a number of paxton guys running the 3.48 on E85, which is 14ish PSI.
There are a few centri guys that dynoed before and after E85 and got 80-105 rwhp.oooohhhhhh hmmm.
Its from a different thread aimed at Phoenix nothing more nothing less. Just a little sarcasm.Thanks Dick!
