800WHP with blower, borrowed time for engine and trans?
Phoenix
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
After reading through this thread I decided to order headers as well. I already have a fuel system and I'm looking for 800-850.
congrats! what blower do you have? :cheers:
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
i know it is not the point of your thread, but yall are gonna love the sound of your cars with the long tubes
NOM3RC
Tennessee
15 GT Premium
I'm a little concerned on loud it's going to be with these corsa xtremes and the arh long tubes lol
Phoenix
Phoenix
Central Texas
RIP eardrums.
venumous
PA
16' Procharged GT
welp. ill at least have headers in the next few weeks to tide me over for awhile :cheers:
ive been told a retune for headers through lund is free?
Yeah should be.
venumous
PA
16' Procharged GT
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
Yeah...you're gonna find yourself in the same boat as I am now. lol
FATHERFORD
Mustang
I doubt you will make much more power, just take a little less stress off the engine.
If you get injectors, get stainless bodies like the 1300's.
A fuel system that uses the gt350 fuel hat and converts to a return style fuel system is good to 900+rwhp.
My 15 runs only 19 degrees of timing, I could easily run 23-25 degrees on the pump e-85 I have and that's on 20psi. Ive been messing around with 25-26psi, but I think i'm starting to max out my 1300's at 50psi. Might be putting on some 67's and swapping to 1700's
Phoenix
Phoenix
Central Texas
why?
why?
similar to the Sai Li system i guess?
thats one thing i can say about the lund tune, its been safe as heck.
jhatley7
2016 White GT PP, 2022 F350
Yeah I only ran 17psi on my stock block Terminator, 18 is a bit high and way more than is needed for 800whp. OP, you could do 11-12psi with timing for E85 and be at 800whp.
Yea should have been upper 800's
Very loud. but sounds good.
E85 is corrosive. Always want stainless with e85.
Phoenix
Phoenix
Central Texas
i meant more of why the 1300s when at 800whp the 1000s should suffice.
ethanol is not much more corrosive than 93 octane but its the attraction of water that causes issues.
jhatley7
Room to grow. I was very close to maxing out my 1000's at 18psi. Could have upped the fuel pressure to 50psi.
RARR_LS2
Saann diaagoo
2015 Mustang GT
FATHERFORD
Mustang
You're still flowing the same amount of air, just less stress on the engine. Should help reduce EGT's and heat in the engine some. From the two I have seen in person, removing just CLOGGED cats is worth about 15rwhp. I doubt adding long tubes would add much, maybe adjust the power band some.
Phoenix said:
Ethonal attracts water and is slightly more corrosive. I think the 1050x is a stainless injector also.
Yeah, you can easily piece it together yourself cheaper, or there are some other places that do the same thing he does for a little cheaper also. With a gt500 boost a pump(two pumps) it was good to over 1050rwhp.
They are very conservative, there are other tuners out there that will post the higher dyno numbers and faster times, but they are running 5-6 degrees more timing, hoping the computer will pull timing if knock due to bad fuel etc.
