- Banned
- #466
Length is the same, but otherwise the Camaro is smaller in every single other aspect. So, as much as you say it's a wash, it really isn'tLength is a wash, front track is a wash, width and rear track almost a wash, and the Camaro's shorter height is offset somewhat by the (lighter) greenhouse height being significantly shorter than the Mustang's.
So, pointing out differences is defensive now? Well, I guess that makes us both defensiveAs good a definition of defensive as I could ever come up with . . .
But the S197 is heavier than the SN95, and your whole point is that any weight gain, regardless of the benefits it may hold, is worse... so, I guess by your logic, that makes you an idiot for buying an S197 over an S550I've known from the get-go that my S197 is heavier than it could have been, and I'm not afraid to admit as much. Or that it has other shortcomings. I'm not afraid to complain that in a couple of respects even my '08 is more luxurious than I really need. I know you're going to flame me over noting that the S197 wheelbase being about 6" longer than the SN95's must have had something to do with that weight gain. But those are discussions for places like S197Forums or AllFordMustangs.
Would I have opted for a lightweighted S197 if it had been available? Absolutely. But not at S197 Shelby Mustang GT (not the GT500) pricing and ADM'ing.
So, if it's not what you're thinking, then see aboveThat's only what you want to think I'm saying. Not much I'm ever going to be able to do about that, I guess.
Except the challenger wasn't necessarily heavier due to amenities, but moreso safety regulations on an outdated chassis. Also of mind, the Challenger is much bigger than both the Camaro and MustangThe Challenger is kind of the poster-boy for the direction the Mustang should never, ever take. Though that might be a reasonable target for a reborn 1960's Mercury Cougar, heavier on the amenities, lighter on outright performance unless throwing more engine and still more weight at is a good enough answer for you.
My definition of better is, simply, better. I should be asking you the same, why can't "enough" be enough? Ford investing plenty in lightweighting for the S550 to keep weight close to the S197... why can't it be close enough? What makes it such an irreversible handicap?Your definition of 'better' must be quite different from mine, and must have a lot of "more for the sake of more" in it. Any reason "enough" can't be enough?
Except you are, because apparently keeping weight within 100lbs of the previous generation while making it significantly better isn't enough for you. For you, it NEEDS to be lighter. That means sacrificing size, power, lateral grip, or all of the above, thus making it more miata-esque... so, if you want low power, low lateral Gs, and small size all in the name of saving a few pounds, why not buy the 1 car that's notorious for doing it best and leave us mustang guys to be happy with our mustangs?No again. I'm not trying to "Miata-ize" the Mustang. Only keep it from becoming "Challenger-ized" (BTW, thanks for mentioning the Challenger).
I hope we both understand that it's nowhere near as simple as that. Not with everything electronically tied to everything else.
It should have been left easier by Ford not including as much even in base trim, or requiring unrelated items you don't want and wouldn't use just to get the thing or two that you really do want. PP2 requiring 301A is almost its own contradiction.
Except it is, you're just too scared to try. Lets look at this with your own example:
Sync3- literally NO weight gain over sync1
Leather seats- easy to be swapped out with cloth, or since you're so concerned about weight, racing seats
And that's literally all there is to 301a. So, what you're saying is that you don't want people who look for these luxuries to be able to have them, because you're too stubborn to do an hour worth of work to your race car or are too scared of about 30lbs at most?
I also must ask... the PP is SIGNIFICANTLY heavier than a base GT in the name of performance... so why are you so dead set that you would buy such a heavier package on a car if it didn't require a package that adds at most 25lbs?
See; Definition- RebuttalFirst mention of Ferrari was from you, correct? I know I didn't drag it into this thread. Anyway, my intent hasn't changed, only the way I've phrased it so that you might understand the thought I'm trying to put across. Apparently without any success here either.
Yes, I brought it into this thread. However, you have had 3 separate rebuttals making 3 separate points. Additionally, your first rebuttal was, very simply, "different strata"... Not necessarily sure there's a point to be made by you
Nope, didn't miss that part. I've also had a pass-by from a MP4, ironically enough in my old 3V. I never said you lived in a depressed area, but considering I live and do all my racing around Dallas, I'd be willing to bet we have quite a higher concentration of high end cars around here. That being said, and as I've already said, I don't recall ever going to a track day event that didn't include at least 1 FerrariYou must have missed where I mentioned seeing a McLaren . . . it was running in my own run group, actually, and that white-ish thing at the left side above the wing in the picture below is a point-by being given.. Within a few minutes walking distance of my house there's been a Lamborghini that gets fairly regular use about town, and Kerbeck/Palmyra is only a few minutes away by car, so it's not like I live in a depressed area.
