Andy13186
You should beat it first before you talk crap, imoI don't know. 4.74 in -400 or something DA? Lol. Is that really impressive considering all the work?
I run a 4.8 in 2000DA at 15psi with a completely stock motor and transmission and full weight of 4200lbs. So I'll say it again. All that money and work he has done AND in mineshaft, hero DA, just to run a 4.7 isn't impressive. Sorry not sorry...lolYou should beat it first before you talk crap, imo
The draggy is just a GPS based timer, it doesn't correct for DA or any other variable. That said, as you probably already know, DA takes into account humidity.Just thinking out loud. I'm in the Airline world. I wonder if the draggy takes into account humidity? I see people with similar set ups, and similar DA running vastly different 60-130. If the draggy doesn't factor in humidity. This may be why there is such a wide range of results.
Yes I stated that wrong. The Draggy has no correction factor. Is humidity factored into the draggy DA?The draggy is just a GPS based timer, it doesn't correct for DA or any other variable. That said, as you probably already know, DA takes into account humidity.
I don't have a draggy, but I don't believe it calculates DA at all. I may be wrong, but I think people just go online and figure out what the DA is at the time of their run.Yes I stated that wrong. The Draggy has no correction factor. Is humidity factored into the draggy DA?
Draggy has the DA displayed along with the temp and Altitude above sea level.I don't have a draggy, but I don't believe it calculates DA at all. I may be wrong, but I think people just go online and figure out what the DA is at the time of their run.
That moving pretty good!!Little better DA and added some more ethanol content, was about E75.
