5w20 or 5w30 (Caribbean)
Xavierviana
Curacao
Mustang gt premium 2015
Hi,
Would you recommend me switching my oil to 5w30 full synthetic?
Car: Gt premium 5.0 automatic 2015
Place: Caribbean
Weather: 80-95 degrees (all year) (semi hot climate)
Driving: Moderate - Hard (100 miles max per week)
Car temp: 205-220
Miles on the car: 25.000
Any advise or comments would help..
Thanks
Xavier V
scrubber3
Hopper, is that you?
Sandhills NC
2017 GTPP Shadow Black. 2001 Jeep XJ 4x4
I would recommend fully synthetic 5w20 or 5w30. So long as it is a good brand and not store branded you should be good with either one.
Xavierviana
Curacao
My options here are Pennzoil Platinum, Mobil One or Castor Oil. Which do you recommend?
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
My memory of discussions on whether or not to change to full-synthetic is that there is plenty of reason to do it, not much against.
On the other hand, I've read that changing viscosity might interfere with some engine functions that are viscosity-dependent. I'm not convinced, since the only mention I can find in the Driver Handbook is to go up a notch or two for track work and go back to recommende specs for street driving.
michail71
2018 GT 401a A10
That is probably for fuel efficiency too.
scrubber3
Sandhills NC
Any one of those should be good to be honest. Pick your poison
GT Pony
Pacific NW
Ford specs 5W-30 for the Coyote in Australia, and Ford speced 5W-50 for the Boss 302 for every day use. Those engines are basically the same internally as all other Coyotes. They will run and be fine with oil thicker than 5W-20, and 5W-30 is fine for street use.
whalesalad
Costa Mesa, CA
2016 GT PP
I ran 5W-20 Mobil1 a few times then switched to 5W-30 Royal Purple. Anecdotally i've heard that 5W-20 is recommended for the 5.0 purely for emissions/fuel economy and that 5W-30 is a better oil for the motor.
I've put 6,000 miles on the current fill of 5W-30 Royal Purple (including a 4-day trip across the United States) and my fuel economy was in the 24-25mpg range. I was expecting worse with the heavier weight oil but this thing did pretty good!
So... 5W-30 will be fine, and Mobil1 or Pennzoil Plat will be about the same. You can't go wrong.
JohnD
Legend in his own mind
beyond the pale
2023 Mach 1 track day car
I talked to Ford Performance about what oil to use in an unmodified engine, mostly due to some people saying these cars need heavier weight oil, etc. Ford Performance said to me, what does it say on your oil fill cap? I told him 5W-20. He said, that's what it's designed to use. I said even on track days? He said yes, even on track days. So be guided by your oil fill cap.
GT Pony
Pacific NW
Should have asked him why Ford specs 5W-30 for the Australian Coyote and 5W-50 for the Boss 302 Coyote for street driving. Seems CAFE really has their hooks into Ford.
engineermike
La
2018 GTPP A10
More importantly, who at ford performance gave you such guidance?
I do think it's interesting that ford recommended 5w50 in the 11-14 track pack 5.0 and 5w30 in 2018+ for "track use", but as far as I can tell no such allowances for 15-17. I did run 5w30 in a supercharged 2015 f-150 5.0 making 640 rwhp for about 40k miles. Consumption over the 10k drain interval was negligible.
