4inch to 8inch
regachoz01
San jose
Zach
2021 mustang gt
So I recently just got my 2021 mustang and it's a base(i'm planning to build from the bottom). I already changed the exterior and I think I'll settle with it for now. I want to change the interior starting with the 4inch original sync. Is the oem sync 3 still worth it for a base since most buttons won't do anything other than the original buttons? I think the dual climate won't work either? If so, any good after market that can replace the 4inch? Thank you!
Bikeman315
Myrtle Beach, SC
Ira
br_an
Boise, Idaho
Bran
2016 Shelby GT350, 2020 Ford F150
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
It's really easy to do on the newer cars because you don't have to do any harness switching and you can leave the stock USB hub. You'll need the APIM module, screen, and bezel from a sync 3 car. I recommend trying to find a 2019 or newer if you want FordPass to still work. You'll also need a laptop with ForScan to set everything up if you want drive modes. You won't get dual zone climate but everything will work normally despite that.
MustangorCamaro
DMV
Honda Accord
Aren't there several aftermarket options that are better than the stock Sync 3? Not talking about Tesla screen but from the normal manufacturers like Alpine, Pioneer, Sony etc. If you're going to upgrade from the base 4 inch unit, wouldn't it be better to set the bar a little higher? Assuming you're OK with the non stock look of course.
samd1351
Olathe, KS
Sam
2017 Mustang GT, 1999 Ranger
Pwny_Exp
NorCal
Jake
'20 GT PP1, '18 Power Wagon, '16 JK, '19 E-Golf
The problem isn't the number or quality of aftermarket head units, it's the dash kits that replace the bezel and HVAC controls. I did that on my 2018 with a Scosche dash kit and this time around for my 2020 I'm doing the 8" sync 3 upgrade instead (and sending it out to an amp).
regachoz01
San jose
Zach
2021 mustang gt
Do you guys know any good aftermarket products?
FreePenguin
Ohio
Donald
17 mustang
I’d stick w oem ive seen some 3rd party units in person, literally watched several freeze on them. They played it off saying it’s rare
but I’ve seen it more than once, my oem has never frozen
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
I am or was in the same boat. The issue is the bezel, the aftermarket by Scoetch and a few others leaves a lot to be desired. I have a base 300a GT and went down the same path.
regachoz01
San jose
Zach
2021 mustang gt
So did you switch to the original oem or stick with aftermarket?
Dave2013M3
El Segundo,Ca
I have an OEM 8" screen I am installing. I have the parts but I need to have my 4g modem fixed and have no ETA on when the part will arrrive.
