475 miles on the new 2019
stangman638
2019 GT350 Velocity Blue
and guess what I am starting to hear? What does capt obvious say?
302@12psi
MD
2019 Kona PP2 Recaros
At some point they have to have this figured out right? It's been going on for several model years and Ford has to be losing money at some point replacing major engine components.
Stormtroopin5.0
Indiana
‘22 Mach 1 on order; ‘18 Mustang GT (sold)
I'm gunna go out on a limb and say this tick issue is way more widespread than it was for previous generations. Nowhere near the amount of 11-17 owners seemed to complain of the same noise compared to us 2018 & up guys. As awesome as the car is, old blue seriously screwed the pooch on this generation....
stangman638
stangman638
Don't hear it on idle, only a few taps here and there when revving to 2k... last week I heard no taps revving to 2k.. waiting to see now how this progresses
Fastfwd
Oklahoma
Jason
2019 Ford Mustang GT 2012 Honda Accord V6 Coupe EX-L Nav
So, if I'm looking hard at buying a 2019 (looks like an August 18 build date)... Would everyone here say don't do it? This is a nearly fully optioned out GT Premium, PP1, Magneride, etc. car that has a sticker over $53k. I'm not paying $53k, but nevertheless it's a really expensive Mustang.
I thought this was some sort of issue that was traced to early builds of the 2018s, but apparently that's not the case?
Dfeeds
Illinois, US
That's what saddens me about my current 2019. 1070 miles, no tick, but it needs a new engine for other issues. Now I'll get the new engine and have the tick.
GT Pony
Pacific NW
The new Gen3 Coyote seems to have it's own unique 2K RPM rattle which the 2015-2017 never had.
Condor1970
Port Orchard WA
At least mine made it to 800 miles. But then, some are typing up the Wall street Journal from day one.
I can't help but wonder what would happen if I installed that LMR A/C belt tensioner kit for the 2011-14 coyotes. I wonder if it would even bolt on?
Kong76
Turlock, Ca
2016 Ingot Silver GT
I have a 16' tick has been there since first oil change and every oil change since. 27k miles currently and It's noticeably down on power. Just been beating the shit out of it waiting for the smoke. All documented. Have a FRPP2 kit from 2016 sitting new in box in the garage. F n sad.
stangman638
stangman638
650 miles, no change, not worse maybe a little better. Revving when park its taps once... not repeatedly, continuing to monitor, not very concerned.
stangman638
stangman638
Doubt it will do anything.. Someone must have really fucked up the CNC machine process on one of the lower end components.. Like cut it wrong.. I can't see the engineers missing it
stangman638
stangman638
taps now 2-3 times when revving in park.. not consistent .. yet like the 2018 I had. Something tells me this wont go away on its own.
Condor1970
Port Orchard WA
Did you see the other thread I did where the old TSB 12-8-14 was issued for the older 2011-2014 GT's? It's certainly not a universal cure-all, but that one guy actually fixed his tick by installing the belt tensioner.
My guess is there may actually be some slight misalignment occurring in some of these engines causing it to tick. Not all of them though. But, I can see how pulling too hard directly to the side with a stretchy belt may causing some slight knock/slap from misalignment. Usually engines have their auxiliaries mounted above, so the tension on the serps pull the crank upward to help it float. Once you start pulling sideways, that's radial movement the rods, journals, and pistons will not enjoy
88lx50
NYC
2018 Mustang GT convertible 6 speed
The question is, why did Ford develop the new belt set up to fix the problem and not make it a standard production item?
88lx50
NYC
Stangman - do you have the rattle as well?
