3th gear lockouts! Need help!
London
Roland
FORD MUSTANG GT PP1 (2022 convertible)
Im looking for a solution to void the 3th gear lockouts on high rpm. What are you guys would suggest? What modifications or upgrades should go with? I have 2 option but om not sure wich is better...
One of them Steeda MT-82 Tri-ex race short shifter the other would be Barton Hybrid 3 shifter flatstick. Heres is the links too
https://steeda.ca/products/barton-hybrid-3-shifter-2015-19-mustang
Or
https://np-motorsports.com/products...-steeda-mt-82-tri-ax-race-short-throw-shifter
Please let me know what you guys think
Thanks
NGOT8R
Adrian
2019 Bullitt
I have the Steeda Tri-Ax Race shifter in my 2019 Bullitt. While it is a much better feel for me than the factory shifter, I doubt that it will solve your issue. However, I do think a better clutch would be a step in thr right direction.
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
3th?
RolandMustangGt
London
Roland
Thank you for comment it could be helpful
I will look into clutch as well! I guess...
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
I recommend the MGW shifter.
An aftermarket clutch may help some. But the stock shifter is pretty sloppy. I've heard some twin disk clutches can help. But either way...I have an exeedy clutch (single disk), had high RPM shifting issues going from 4th to 5th. I then installed an MGW race-spec shifter and haven't had an issue since - it also made all other gear changes much smoother.
The steeda tri-ax shifter is still mounted to the body of the car, so it may not resolve all issues related to that. MGW is trans mounted. The barton lets you mount either way (and keep reverse lockout if you want it).
AZlb5.0
Arizona
Carlos
18 GT Premium
Our stock shifters are mounted to the body. That could be part of the problem also. If you don’t want to spend the money you can get it mounted to the trans. Which could work.
KingKona
Virginia
Shlomo
2019 GT
An aftermarket clutch may help some....I've heard some twin disk clutches can help....
The stock clutch is a twin-disk.
I would imagine it's fine, and the throw-out bearing or slave cylinder might have an issue.
Howitzer
NC
flickr.com
Howie
Ah - didn't notice he was Gen3 - Gen2 is single disk. Either way, they aren't all created equal.
KingKona
Virginia
Shlomo
2019 GT
It's 3rdteenth.
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
