355 torsen
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I have a 355 torsen that I got done installing . Is normal for the tires to rotate when the car is park and in different
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Could you restate the question?
With the torsen, If the tires are off the ground, if you spin one, the other will spin the opposite direction, yes.
if you’re driving and one tire is completely off the ground, you can’t put power down through the other (the tire off the ground will spin).
Torsens are awesome, but those are two quirks.
NightmareMoon
On that note do you suggest I get a 3.73 torsen or just 3.73 gears in the base diff if that is possible (sorry to hijack).
Best to start a new thread or post in CAMC thread.
Lbj
Lbj
Larry
Sorry I should have asked why are the wheels turning when the auto transmission Is in park the drive shaft not turning at all and the brake calipers are not on the roters yet
NightmareMoon
Thats a complicated question and I’d have to direct you to youtube to look at how Torsen diffs work. Short answer is its normal if both wheels are off the ground. no worries.
RicardoC50
California
Ricardo
2019 mustang gt
Hey I have a 3.55 torsen diff that I’m wanting to install, did you have to use forscan or custom tuning after the gear change or will the car just accept the new diff without having to do anything?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
There seems to be some conflicting info about this. When I did my car it learned everything by itself. Others have said they needed to change the programming.
So, flip a coin.
RicardoC50
California
Ricardo
2019 mustang gt
So, flip a coin.
Yeah I’ve seen the same on this forum, either it’ll just work or will require some type of tuning to set the new shift points. Guess I’ll find out soon enough. What year is your stang? If you don’t mind me asking.
K4fxd
NKY
Mine is a 17
Lbj
Lbj
Larry
No I have the ford performance tune so I just used the pro cal to change it and my car is a 2019
ZeroTX
ZERO
2022 Mustang GT
Just curious, my '22 base GT has the non-torsen limited-slip w/ 3.55's.... What's normal behavior for this one?... And why would I want a Torsen? Real question, no idea.
RicardoC50
California
Ricardo
2019 mustang gt
From what I’ve heard you want a Torsen for track use and non Torsen for straight line drag racing.
