The_Fireball
Done a lot of reading and none the wiser so looking for some answers. I've got a new set of SVE350 rims at 19x11 for the rear and 19x10 front. These replace the existing UK GT wheels (PP wheels). According to this tyre fitment guide, the ideal like for like with these wheels, maintaining staggered setup and no adjustments is:
Front: 19x10” ET40 with 285/35/19 tyres
Rear: 19x11” ET52 with 305/30/19 tyres (results in shorter rear wheels though)
My existing/old setup is:
Front: 19x9” ET45 with 255/40/19 tyres
Rear: 19x9.5” ET52 with 305/40/19 tyres
I've recently had a new set of PS4s on the rears of my existing setup, so was hoping to move them to the new fronts (becoming 19x10 275/40), and just get a new set of rear tyres. Seems a shame to bin them, plus that's ÂŁ450 of new rubber for nothing. The question is: what to put on the rears? 305/30/19 or 305/35/19 are both going to come in shorter on the rears then the 275/40/19 on the front, which is going to look off and I presume not be great for the car geometry. Worth noting I've got the Ford ProCal tool that allows you to code in a new tyre circumference to ensure speedo vales are correct after a change.
305/40/19 would fix this, but it's not clear if that is even feasible. Guys on this thread say that a 305/35/20 works. Now according to willtheyfit.com, the 305/40/19 setup would only be 5.1mm taller overall, so presumably that works. I just can't find anyone else listing 305/40/19 as being used.
Add even more to this mix - I've got the Performance Track Handling Pack to go on soon, which will drop everything 1" all round. I suspect I know the answer here: new rubber all round...or will 305/40/19 work on the rear without rubbing and messing around? If it is new rubber all round, why not go for 305/35/19 on the rear so they're not lower then the front wheels?
Help greatly appreciated!
