3.8 pulley with 20% overdrive?
Pincushin3819
Pincushin3819
SC
17 Paxton GT
What blower?
It will be a Paxton 2200sl. I have the stock 3.8 pulley on the head unit with the 20% overdrive right now. I know simple math is supposed to add 20% more boost but I've seen conflicting logs that have shown more & especially how these cars rev up.
I made this thread trying to see if I was safe boost wise on 93 but after seeing some guys making north of 15lbs I decided to wastegate it with the 12lb spring & add a 3.6 pulley to get into boost quicker. I hope with 3.6 & OD I will get the same benefits as the 3.33 pulley wastgated without the belt slip.
Azmike
9's are easy!
Peoria
I have a 20% overdrive and a 3.6 pulley and have seen 17psi at max rpm but average 15-16 psi. I have data logs i have done and sent to Lund and no issues!
Pincushin3819
Pincushin3819
SC
17 Paxton GT
On 15+ psi you are dedicated to e85 only, right? My tuner doesn't want to be over 12.5-13 psi on 93 but said that I could get a separate tune for e85 & could go to 15+ psi on e85 but wouldn't need to go that high for my goal of 750whp.
What kind of power are you making with E85 & 17lbs?
Azmike
9's are easy!
Peoria
I am on E55 technically because our law makers did away with E85 in Arizona. Yes i am dedicated to E55 full time. As for Dyno i haven't been back since we are fixing a belt slip issue. But at 14 lbs i ran a 9.98 in the 1/4 and at full factory weight.
Azmike
9's are easy!
Peoria
Who is your tuner?
dubster99
Nor*Cal
2015 Ingot Silver GT PP
You'll need a return fuel system to go that high on E85.
dubster99
Nor*Cal
You should be good to go then.
