3.73 to 4.88 Gear Swap Problems **RESOLVED, STEEDA TUNE FIXED ALL ISSUES**
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
The 18 and up and especially a Bullitt with a GT350 intake makes power right up until 7,500 RPM unlike the 17 and down where they kind of Peter out after about 6,800.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
15-17 Manifold take a nose dive after 6500 haha. But again, not the point. Point being is that Ford decided to take the wide ratio route with the MT82, which effectively neutered it. But nothing is stopping the 15-17 guys from throwing on a GT350 intake. Cheers.
RazzaRossa
West Coast of Florida
Ron
2019 Mustang GT Premium PP1
Other than money, what would it take to swap the tranny and whatever else is needed to the new Mach1 set-up Into an 18/19? Sounds like something I would consider if/when they become available.
L0566Bullitt
L0566Bullitt
NC
Jon
2020 Bullitt
Think it would all depend upon if the bell housing bolts up. Which I'd assume it would since they're both 5.0s
shogun32
Northern VA
powertrain and maybe chassis controller and it's programming. probably cheaper to just swap cars.
WildHorse
N/A or GO HOME
'17 S550
RazzaRossa
Ron
ButI dont want to shell out for a new Mach1. Some one will figure out what actually needs to be done. I can wait.
Brazos609
2015 GT Premium PP Recaro
Several people, both 15-17 and 18+, have swapped in the TR3160 out of the GT350. I have a TR3160 sitting in my garage waiting already. Only tuning to program the different gear ratios as far as electronics go. Mechanically everything is bolt in because the chassis is the same and the engines are part of the same "modular" engine family.
shogun32
Northern VA
right and there was a long thread on a Tremec swap that only ended in tears and revert back to MT82. On a 70-80's car it would be no brainer because no damn computers getting in the way. If you just want a tremec in the mechanical sense you can. But reverse sensor, rev match and anything else that is computer-involved will not work at all or only partially. Would it quality for an 80% solution? Probably.
Brazos609
A Ford GT350 TR3160 or another Tremec XL model, the second involves substantially more work. I believe that the GT and GT350 use the same reverse and temp sensor and it plugs right in. No custom driveshaft, mount, or shifter, direct Ford for Ford parts swap.
Speedycrw
Western Michigan
2019 Bullitt K1913, 2010 Mustang GT (racecar)
LOL566Bullitt Thank you so much for this thread! The Bullitt's horrible gearing has been bugging me so much since I bought the car. I LOVE everything else about her. I was wanting to do the 4:56 swap, but you have me mulling on the 4:88s.
I am used to wheelspin, and LOVE the power of my manual transmission Hellcat....it will spin the tires if you are rolling and drop the hammer in 1st, 2nd, somtimes 3rd, and if you are doing a burnout can spin them all the way to 4th (so I have been told). Given the fact that I like the Hellcat for this reason, I think that the 4:88s might be the ticket for me. Again, I can't thank you enough, you will let me make my Bullitt the perfect daily commute car in the summer!
L0566Bullitt
L0566Bullitt
NC
Jon
2020 Bullitt
Go 4.88. You will not regret it. It's perfect in my opinion. I can break traction in 3rd if conditions are right. Shoulda came from the factory with 4.88s
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Problem is that 2019 and up cars have auto rev matching which is done with a hardware change to the transmission, involving a hall effect sensor and harness that tells the computer what gear the car is in, which is information it HAS to have. So the only way to defeat this is if the Mach1 has the same plug and same sensor in the Tremec. But even then it will likely prove problematic since the Tremec will certainly have different gear ratios.
GreenS550
Bob
If you've been reading this, the OP fixed the problem including rev matching with a Steeda tune.
FTIW, you still need a tune on the 17 and down cars to get them to run correctly with a gear change. I know this because I swapped differentials and the car did not run correctly. I got a tune and it was fixed. Since then I've ordered a Forscan tool and will change the car to stock, change the gearing with Forscan to have it run correctly without a tune
I am guessing Ford built in different gear changes in the Mach I like the 17 down. But maybe not up to 488. I know they have a 410 in the computer as I have seen it.
