Norm Peterson
corner barstool sitter
I wouldn't count on there being any difference below 3rd gear. When shifting into 3rd or 4th it ought to be a little easier to avoid chirping the tires, though.The next question I have is , does the 4.56 also spin wheels and in which gears?
You'd still be pedaling it on any hero 0 to 60 run.
It's not quite that simple. Actual contact pressure is not uniform due to tire carcass stiffnesses, and it also varies with inflation pressure. That's before considering that tread grooves don't provide any tread contact with the pavement.I also believe the area of the contact patch doesn't change. All you are doing is changing its orientation.
Maybe, maybe not. As long as you can spin the tires, rotational wheel effects aren't going to hurt you, and could possibly help.Going to wider tires also means that your wheels will get bigger increasing weight and rotational mass is not a good place to add it. That will slow you down too.
Engineering compromises tend to be like that.No free lunch.
Norm
