nicktechla
- Sep 21, 2015
- Los Angeles, CA
- Website
- www.nicktwaddell.com
- Nick
- 2017 Camaro ZL1 Red Hot
I got a manual to row through all the gears... The day my clutch goes is the day I'll buy a new clutch/flywheel.
Exactly this.The rev-matching feature (more like rev-hold) works well if you put the car into the gear it thinks its going in next. If you skip gears, its additional wear on the clutch as it thinks you're putting it into second and holds the RPMs there when in reality the RPMs should be lower because third is a longer gear (duh).
If you skip shift and the car holds the RPMs for a lower gear when you're going into a higher gear, you will cause excess wear on the clutch. I tried this a couple times because I was curious if it was possible and you can easily feel the clutch have excessive slip then bite.
It feels like an eternity lolOr you could just hold the clutch in a little longer, until the rev hold disengages. (takes like 2 seconds)![]()
Your report back will have no relevance because it's impossible to have a control to compare it to. Unless you can drive the car with rpm hold for one clutch life cycle and then disable the feature and drive on the second clutch exactly the same as you did on the previous clutch. Which is near impossible for a human. Granted it's not a big deal, I'm just pointing out it does increase wear on the clutch in these cars. Because as you pointed out rev matching is better on a clutch and you can't do that on this car in as timely of a manner when skipping shifts. I'm not saying people shouldn't do it, just that it increases wear.I'm not the slightest concerned. Just drive the car and enjoy it! I'll report back to you in a few years how everything is holding up.
Yes I do. Heavy duty trucking learned me.Don't you people double clutch while downshifting? I have not seen one post about it.
It is crucial to know how to use it and how to do it...properly.
Very civilized compared to what I do. :headbonk: I like to start in 1st and run up the RPMs, although it just occurred to me that I am running factory exhaust, and plan to keep it that way. People with custom exhaust probably make a heck of a racket doing something similar.Example of a 2nd gear start.
Ignore my shitty, creaking driver's seat. I need to warranty that.
I get your scientific view but my point is...If the trans holds up then the increased wear doesn't matter and should not be of any concerns to skip shifts. Does it increase wear that'll be an issue to decrease parts longevity...most likely not. Carry on.Your report back will have no relevance because it's impossible to have a control to compare it to. Unless you can drive the car with rpm hold for one clutch life cycle and then disable the feature and drive on the second clutch exactly the same as you did on the previous clutch. Which is near impossible for a human. Granted it's not a big deal, I'm just pointing out it does increase wear on the clutch in these cars. Because as you pointed out rev matching is better on a clutch and you can't do that on this car in as timely of a manner when skipping shifts. I'm not saying people shouldn't do it, just that it increases wear.
