2M Fabrications Review (Headers)
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
I must be confused cause all I see on my motor mount bracket is the holes for the bolts into the block and the hole for the engine mount stud. Don’t see how I could adjust it
The hole for the stud is slotted for some left and right adjustment.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
On mine the hole the engine mount stud goes through is slotted so you have a little bit of side to side movement for the engine.
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
I wonder if I could get mine to move a little. I didn’t take the nut off and I can’t remember how big the stud hole is. Will have to try to move it later
tdstuart
tdstuart
Arizona
Triston
So I moved the engine as gas as the engine mount brackets would allow. It’s a lot less rubbing but they are still touching. I think I’m going to dent it a little
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
You’re probably going to have to do that. Any word on the leaks?
tdstuart
tdstuart
Arizona
Triston
No I didn’t look. I’ll have a let better view tomorrow when I attempt to dent the header. I’ll see if I can’t tighten the bolts and clean the oil so I can keep track of it
tdstuart
tdstuart
Arizona
Triston
Update: new motor mounts solved my issue. The driver side motor mount was bad and was sagging a lot.
Wondering if I should just edit this thread or make a whole new one detailing the experience…
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Really?? Im shocked that would make that much of a difference. How many miles on your car?
tdstuart
tdstuart
Arizona
Triston
Ya the driver side motor mount failed. It still held the motor but was sagging and leaking.
Car gas about 102k miles
tdstuart
tdstuart
Arizona
Triston
I have updated the original post to include new information and will add a bit more later.
tanks550
Alabama
Todd
2018 Kia Stinger GT1
So got mine installed today. Pain in the ass but doable. How is everyone getting by the check engine light. P0135
tdstuart
tdstuart
Arizona
Triston
From my research that’s a crank relearn code. Not sure why it is throwing that as you shouldn’t have had to touch the crank, flywheel, or trans.
Do you have an RTD? You can do the crank relearn procedure with hp tuners. Also did your tuner send you a tune for the headers?
tanks550
Alabama
Todd
It's not crank relear it's the O2 sensor. Probably need to replace that one. I use Lund and have read they don't tune for headers.
larr12
Alberto
2020 Mustang PP1
Lund will do a revision for the headers but wont touch emission related CEL.
tdstuart
tdstuart
Arizona
Triston
Oops accidentally googled P0315 lmao.
Is that O2 sensor using an extension? The extension could be faulty. Also try to see if you can check the voltage.
Tuners won’t do tunes that will mess with emissions checks. But they will tune your car so it runs properly with headers. Your cel is your car just saying that there is an issue with the O2. So if you put an extension it’s most likely the O2 extension is faulty. It’s very hard for me to believe you could have damaged the O2 or let moisture get into it while doing the install.
