2M Fab Performance Pipes(Cat Delete)
Serp305
Miguel
Mustang GT 2019
ohhhhh kkk, but you mean drivers side for flange corect? passenger side should just be plug and play since that exhaust manifold has a flange aready...
Thanks Anthony
Yeah my bad it's the driver side that has to be cut and flagne welded, Passenger side bolts on easy.
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Bet! Thanks Serp. Im gonna try and get the 2011-2014 drivers side header as well. Make life easy and save those cats....
2004mustanggt
Tyson5377
Michael
2020 Jeep Grand Cherokee
I got mine installed few days ago with a H-pipe but cold starts at 7am it makes me feel embarrassed thinking about neighbors 😅, what's your mid pipe? You got any resonators?
I just installed these cat delete pipes the other day and cold startups at 7 AM is a huge problem for me. I have an x pipe. What was your fix for this? Did you change your exhaust at all?
robvas
MI
2011 GT
what mufflers do you have? You may need to add a middle resonator to get it down to tolerable levels without cats. It makes it so much louder when they are removed
Serp305
Miguel
Mustang GT 2019
Get 2 Vibrant Performance 1792 Bottle Style Resonator from Amazon, go to a decent shop, make them weld the resonators into your X-pipe, typically before the X, that should tone the volume down and get rip of some rasp.
2004mustanggt
Tyson5377
Michael
Borla s type
stannypack
NOVA
2022 Mustang GT
stannypack
NOVA
2022 Mustang GT
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
I bought a set of these pipes a while back but I haven't install them yet, I know you have to cut driver side cat and weld a flange to make them fit, has anyone gotten these installed on their car and can give a review? Also how much the shop charge you?
Its a nice kit for the cost. I spliced cats into mine which was a bit tedious. The fun part is welding the flange onto the header. You should really take it off to do it right. The outlet is oval. By alot. we heated it and beat it with a hammer round to fit the flange. We took turns wacking at it as even with heat it moves sloooow!
You could tack the flange on the car but at the very least, disconnect the battery lest you blow up a module. All of those modules are chassis ground so even disconnecting the battery has its risks. I marked it. Tacked it out of the car and then checked the fit, tweeked it a bit. I also cut the straight section on the drivers side much like the oem pipe. I welded a coupler to the front half, cut a slit in the coupler and then clamped the back s shaped into the front pipe. That lets you fine adjust things a bit.
stannypack
NOVA
2022 Mustang GT
I got my 2M kit new off facebook marketplace, is there supposed to be 1 or 2 flanges to weld on? I only have 1 which confuses me because once you cut the driver side cat off, won't you need to weld 1 flange onto the header side and 1 flange onto the cat in order to bolt them back up?
Also do you know the purpose of the 1 gasket that was included?
s550_kenny
2021 Mustang GT PP
How long did it take to receive your kits? I just ordered mine 2 weeks ago. Hopefully no issues with the reducers/clamps like I've been seeing...
tosha
Canada
Mustang GT PP1
Please keep the thread updated on your experience. I thought of ordering a kit myself, but their FAQ states the following:
Do you have __________ item in stock?
- We will keep this page updated with in stock status. THIS IS UPDATED DAILY
ALL ITEMS ARE IN STOCK UNLESS LISTED BELOW.
- All Items Are In Stock except GT Cat Deletes and Double X pipes.
And with their f*u attitude I'm hesitant to order from them.
s550_kenny
2021 Mustang GT PP
I actually didn't even want to order from them myself, as I see they more than likely just get their stuff from Aliexpress but they're the only entity online that sells cat delete pipes at that price range. I couldn't even find their supplier on Alibaba either to order directly from them, so I imagine they may have negotiated with one of the Chinese companies and sent over specifications to have pipe bent and welded. Lethal performance doesn't offer cat deletes anymore and MAK wants $700 so I settled on paying the $350 they wanted. I considered having a muffler shop just chop the cats off but I really didn't want to have my stock headers cut up unnecessarily. Time will tell if it was a good decision or not. I hope everything comes correctly in the kit, otherwise I'll probably have to contact my credit card company...
Robottrainer
Canada
If you can get passed the attitude, the kit is pretty decent. I fabricated cats into mine.
