2k rattle twist
nustang
BC, Canada
2020 GT, performance pak, active exhaust
apologize for what must be yet again another ....
So a couple weeks ago I discovered I notice the sound of loose lifters tapping at 1-3k depending on variables.
this am - in quiet mode leaving the house when cold & im thinking hmmm too good to be true. tapping is gone.
So get on the feeder st, and switch from quiet to normal.
tapping is now on
back to quiet, and 2k rattle is 98% gone, only a bit of rattle here and there and quiet,
Back to normal and loud rattle back on.
So guess my workaroud is start in quiet, and once warmed up, switch to normal or whatever.
Thought I'd pass this on as for the life of me I cant see a corelation to exhaust restriction and piston slap/whatever ...
Fairly sure its not injector noise, I'm used to that from GDI cars. So injector pump I see has been suggested as well. Could be something that hasn't been noted before.
Youtubes of 2k rattle are subtle as road noise tends to mask it ... but did hear one where the 2k rattle recorded is what I'm hearing.
So submitted to the academy for evaluation ;)
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Are you sure the rattle comes from the engine? These sounds can be extremely deceptive, they can often seem to come from a completely different direction.
I seem to remember reading some time ago about the active exhaust valves getting a bit loose and rattling, though I can't remember the exact thread. If it's the valves that rattle, that would explain why the noise goes away in quiet mode (valves shut, so they can't rattle) or after the car warms up (hot exhaust, meaning less play due to the dilatation of the various parts).
Ock
Tn
Tom
2018 GT Premium and a 1966 c10
check cats.... :p
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Do the active valves create a subtle rattle?
EFI
Masshole central
5.Br0
tapping is now on
Sounds like the "rattle" is with the valves inside your active exhaust.
pmor4243
Utah
Parker
2019 Mustang GT
I can say that turning my exhaust to quiet doesn't do anything but make the rattle more noticeable since the exhaust isn't drowning it out anymore. It doesn't get louder, you just hear it better. Had a local performance shop that does a lot of work on mustangs look at mine and they felt that it was noise associated with the cam phasers and while annoying, not really problematic (at least on mine). Seems to be possible since different tunes on mine will make it much louder depending on what is happening with the timing.
TonyNJ
Northern NJ
www.instagram.com
Tony
I recently discovered my AE valves are rattling in my 19 GT. Has anyone experienced this and cured it? I just past the 3/36k last week so I'm sure it's out of warranty.
It's not horrible but I can hear it when the valves a fully open and I'm off throttle coasting around town. The sound reverberates off whatever I'm coasting past. Not a good look. @Vlad Soare @EFI @Whitedevil95
Exhaust is emissions related, and the Ford emissions warranty is 8/80k, whichever comes first. I’m pretty sure the AE would be included with “emissions” since it is the factory exhaust. Make an appointment with your Service Center or inquire with them. All of the Ford Warranties are outlined in the original Owners Manual.
