2022 GT Dash display
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
All I wanted was the option in "my gauges". But now I want both LOL
Could a flaw in my install make the gauge unavailable?
Or do I need a new Forscan tech?
The gauge availability is all dependent on the IPC configuration but they aren't all on or off settings. Configuring the PP gauges takes them off the IPC display.
mookieit
tampa
john
mustang 2015 v6
I added a diff temp sensor to my non-PP 2022. Sensor is maybe like $20-30. Pigtail connector the sam-ish price and then I ran the wiring myself to the harness under the rear seat. Then you can use FORScan to enable the sensor. Overall pretty easy to do
Is there any tutorial you can share please on how to do this on base s550?
Trace
Trace
Lake Ashby FL
Trace
2021 Mach 1 HP Elite A10 / 2022 Mustang GT Premium / 2019 F150 STX Sport 4x4
Jay I think I understand what you're saying... what is IPC? Instrument panel cluster? Just a guess
Trace
Trace
Lake Ashby FL
Trace
Mookieit- it's all in this thread. Except the computer flash. That's where I'm having the problems
Pistolpetem9
Iowa
David
21 mustang gt
I’m not in my car right now but when you hit the pony button, goto gauges and change layout. You can choose to have a layout all of the time ( normal, sport+, track) or change with drive modes.
Trace
Trace
Lake Ashby FL
Trace
Jay just to be clear... your car is a non-PP GT? Like mine? Are we apples to apples?
Trace
Trace
Lake Ashby FL
Trace
Pistolpete- how about yours? PP package or no?
Pistolpetem9
Iowa
David
21 mustang gt
my car does not have performance pack. As long as the car has the digital gauges, the functions should all be the same minus a few things that are unique to a Mach 1, Bullitt or Shelby.
MrBD1348
Chicago, IL.
'22 GT MT-82
Standby I’ll go out to my car and take FORScan screenshots
Trace
Trace
Lake Ashby FL
Trace
Thank you for this. I have a VINT-TT55502 but I haven't had the confidence to try it. I'm not very techy.
Could you look at post #27... can I get to this display (top one) in my car? Or is this from a Shelby or some other build?
MrBD1348
Chicago, IL.
'22 GT MT-82
that display should just change with the drive mode change. Top cluster is sport mode. Bottom doesn’t appear changed
Jaymar
Portland, OR
Jaymar
PP and Shelby cars have the two gauges in the center dash and because of that the functions get removed from the IPC module (Instrument Panel Cluster.) When you reprogram with Forscan you are reconfiguring multi use modules, you aren't programming so you can't make anything happen that isn't already there to be used in some vehicles. In this case, we are trying to configure the IPC to display the axle temp displayed on the Shelby car but we get limited by a module limitation because of our lack of all the hardware. Best compromise for me was to leave it available as a selectable gauge only as it is merely a curiosity. To do that you only need the single line change mentioned in the above and attached threads. It is also a quick change with a shortcut in the Forscan easy change sections if you don't want to get into the bits. My comparison to a GT500 as-built was just to confirm I wasn't leaving any stone unturned.
Trace
Trace
Lake Ashby FL
Trace
You said "selectable gauge". Do you mean it will display here?
