Epiphany
That is not how it works, at all. It is the fastener stretch that works to maintain the proper amount of preload and inherent friction created. You never jam a stud into a blind hole with the idea being to "keep it there." You must apply the proper amount of stretch through an engineered/calculated torque figure, in this case at the nut due to it being a stud. Without enough torque applied through tightening of the nut, the fastener will fatigue and eventually fail. Never under or over torque a critical fastener or you risk a failed connection that can yield disastrous results.If there was any material degree of 'friction' and it rotates the stud, the already cured locktite is now shattered. I would be inclined to use 15-20ft/lb since it's a M14x2 fastener... You don't need a lot of torque on the nut holding the caliper on the stud - you are simply making it tight enough so it doesn't come loose. There should be no actual stretching of the stud nor deformation of the threadform.
All the force is in sheer - nothing pulls back on the caliper so 'tightness' is not critical to operation.
Fastener stretch, in the proper amount, is everything. An engineered fastener can go through a near infinite amount of proper stretch cycling. Again, under torque will lead to fatigue. Over torque, and you risk yielding and creating a "plastic" or permanently deformed fastener.
