2019 GT PP2 with less than 200 miles does exist
GR1MxREAPER
Minnesota
CJ
2019 Mustang GT Premium
I’m so Confused, it literally takes 30 seconds to take a pic of the car and the mileage with a weird object in it (spoon/shoe) and then Atleast you would have everyone’s attention. As far as his 580hp car, he did say it was 580 motor… so if it’s an auto and you lose 16-17% driveline maybeeeeee it could be true lol.. 480ish to the wheels. Maybe a small shot of nitrous or a fully built block and every mod possible and a happy dyno? I doubt it but maybe 😂. Either way post some damn pics and put a spoon in it since someone said that.. 🚗
PS: My 2019 PP1 has 15,000 miles so kinda low, we can start a 2019 low mileage club. 😂😂
Paddles
TX
Richie
2023 Mustang GT
If it's possible I really want to know.
I would go modify my 3v right now.
An S197 with 480 N/A to the wheels would be kickass.
TonyNJ
Northern NJ
www.instagram.com
Tony
I’m so Confused,
And that's the real take away from this thread. It was meant to confuse you. Beware! They're out there in this world. All sorts of miscreants just looking to sabotage your mind with nonsense. Don't feel too bad. We all get caught in the trap occasionally.
Go forth and do great things my friend.
geep81
Cleveland OH
2020 GT Premium
Enjoy the car... PP2 in my opinion is special, but not collector grade. It is a GT with additional suspension bits. That's it.
That's not true, there is more to PP2 than that such as better cooling/more radiators. It's way more set up for track days than a PP1 is.
Ewheels
SoCal
Eric
False.
The PP2 has the exact same radiators/coolers as a PP1.
The PP2 came with Magnaride standard (which you could option on a PP1) and it came with much wider wheels/tires and Cup2's. The tires are the real differentiator on the PP2.
Oh and it came with some extremely mild aero bits.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
False.
I thought it had a larger radiator too? and different magnaride programming and some different suspension bracing?? we go thru this every time.
Ewheels
SoCal
Eric
Nope.
PP1/2 have a larger radiator than a base GT but PP1 and PP2 are identical.
Also neither have trans cooler, diff cooler, or engine oil cooler. They have that oil/coolant warmer thing (actually works decently well) but nothing like the GT350/500 or Mach 1
Goterr0r
St. Louis
Chad
2022 Mach 1
The one thing nobody ever brings up with the PP1 and PP2 wars... PP2 can say they PP is bigger. Isn't that what we are after anyways.... :)
Ewheels
SoCal
Eric
It's not bigger, they just have two rather than one...
cerbomark
TN
Equipment Group300A 301A
Free Standing Packages & Options (FSO) (continued)
Performance Package – Level 2 (Fastback Only)
  • 19x10.5 (F) / 19x11 (R) Dark Tarnish Painted Aluminum Wheels
  • 305/30/R19 Michelin Pilot Sport Cup 2 Tires (Summer Only)
  • Brembo Six Piston Front Brake Calipers w/Larger Rotors
  • “Engine Spun” Aluminum Instrument Panel
  • Gauge Pack (Vacuum and Oil Pressure)
  • High Performance Front Splitter
  • K-Brace
  • Large Radiator
  • MagneRide® Damping System with Track Inspired Calibration
  • Strut Tower Brace
  • TORSEN Differential with 3.73 Axle Ratio
  • Unique Rear Spoiler
  • Unique Track Inspired Chassis, Stability Control, EPAS, and ABS Tuning
  • Unique Track Inspired Springs and Sway Bar
    Note: Not Available with Spoiler Delete (13D), Engine Block Heater (41H),
    10-Spd Automatic Transmission (44U), Black Accent Package (52B), Mini Spare Wheel and Tire (66W), Performance Package (67G), or available wheels (641 or 647)
673O
GT Performance Package
  • 19" X 9" (F) 19" X 9.5" (R) Ebony Black-painted Aluminum W heels
  • 255/40R19 (F) 275/40R19 (R) Summer Only Tires2
  • BremboTM Six-Piston Front Brake Calipers with Larger Rotors
  • Gauge Pack (Oil Pressure and Vacuum)
  • Heavy-duty Front Springs
  • K-Brace
  • Larger Radiator
  • Performance Rear Wing
  • Silver Painted Strut-Tower Brace
  • TORSEN® Differential with 3.73 Axle Ratio (Manual)
  • TORSEN® Differential with 3.55 Axle Ratio (Automatic)
  • Unique Chassis Tuning
  • Unique Stability Control, EPAS and ABS Tuning
  • Upsized Rear Sway Bar
MAGS1
Somewhere in Middle America
2022 Mustang GT
PP2 will also sit lower because the tire diameters are shorter than PP1
Ewheels
SoCal
Eric
DM_BK
D
2019 Mustang GT PP2
I realize there is more to PP2, but I don't consider it "collector grade" like a GT350R, where there are bespoke parts. Special? Yes, but not the type to put in a garage and oogle.
