Leosegura155
- May 10, 2021
- Eagle pass
- Leonardo
- 2019 Mustang GT
Just put in my new sync 3 without gps. Iām trying to put drive modes but it says my obd isnāt compatible (the one you suggested and other videos too) not sure if I have to keep trying till it reads it. Also never found the ACM as I saw in a video but here you label it as ABS?? Not sure which one it is nowUpdate: I can only speak for the 2020, but no additional wiring is needed. Do not purchase or change your harness if you own a 2020! I purchased a Bezel/Radio/ACM/APIM from a 2019 and it was plug and play.
DO:
If you plan on upgrading your 2019-2020 without utilizing with Forscan, it will work. The only function missing will be the Drive Mode toggle switch. However, you must sync your fordpass PRIOR to installing the new unit. It will not work with the new system. The fix is to pull your dash and reinstall your old radio to sync up as the VIN will not match and you will not get the authentication notification. With Forscan, you can update the VIN and fix this as well.
Upgrade your radio to the newest version of Sync using a USB flash drive. Over the air updates did not work with my system, but your mileage may vary. The update takes about 20 minutes and it is very much so worth it if you are running 3.3 or older.
DO NOT:
Use master reset unless you have no other option. If you reset your radio, it will disable your MyFordPass authentication. Without updating the vin or reinstalling your old radio, there's no way to connect your fordpass to the new system. You will lose the remote start/lock functions on your phone.
The 4" to 8" thread has a ton of good information, but it does not apply to 2019's and 2020's. I've done some research and have decided to do a write up with what I learn throughout the process. I've got my screen/APIM/ACM on the way and it should be here shortly. I will try to document the installation with as many pictures and videos as possible.
What I've learned so far:
The Shelby GT350/GT350R Bezel will not work with a base interior. You have to get the premium bezel. The switches are programmed differently and will not interface correctly.
In previous years, a custom/modified harness is required. However, for a 2020, the plug from the base model is the same.
The USB hub (At least in my 2020) is the correct hub for apple car play.
You can enable drive modes through Forscan if you upgrade to a Premium Bezel. Here's how:
Enabling Drive Mode Selector Toggle with FORScan:
Connect your OBDII Coding Tool to your car and computer. Switch your tool to the HS-CAN feature. Turn your ignition on, but do not start the car.
*I purchased This OBDII Module and it was compatible with windows 10 and my car. No drivers were needed.
Open FORScan and follow the prompts. It will ask you to switch it from HS-CAN to MS-CAN to read the modules in the second position. Do this and press OK.
Click the "Computer Processor" image and select ABS (As Built). Press the blue Play button and let the module load. Find line "760-02-02" and change the following numbers:
xxxx-3xxx (ONLY change the fifth number. Leave the numbers in the X slots be)
If you own a performance package car, change it to xxx-7xxx instead.
Hit WRITE.
Select the STOP button at the bottom of FORScan.
Now select "IPC" on the same list as before under the computer processor. Find lines: "720-06-01" if you have an automatic. Change the code to 6C7F-8000-18B1. If you have a manual, change the code to 786F-0664-1897.
Hit WRITE. Turn off ignition and wait a minute or two. Start the car and enjoy your new toggle switch!
