15guardGT
- Dec 8, 2014
- Rockingham, NC
- 2015 Guard Green Auto GT
So I checked over the forum and found a wiring diagram showing the detailed wiring on the factory amp and what the wires coming into and out of the amplifier were and proceeded to do my own amplifier bypass on my 2018 ecoboost.
Well, after installing all new component speakers (minus the center dash, not using it at all anyway), adding a 5 channel amp and running all the wires...the dash no longer worked, the radio has a backlit dark screen (can only tell there is a backlight in the dark, otherwise the screen stays black). The car starts and runs fine, drives good sans the fact the instrument cluster and radio are dead.
So, I did some more digging on this forum, and while I did find a solution to the issue (only apparent after realizing the problem), I didn't find the problem. Turns out the factory amplifier (DSP) cannot be completely bypassed using the line in and speaker outs. The DSP is linked into the canbus and kills the canbus signal for the IPC, APIM, TCU and maybe another acronym or two if you completely disconnect it (all three connectors, primarily C2385A, which has the canbus hi/lo wiring (pins 15 (green) and 16 (white).
Also the line in stuff shown on the wiring diagram in the sticky doesn't match what my 2018 has after purchasing the motorcraftservice 72 hour subscription, as it only shows left and right audio outs, nothing for front and rear, just left and right.
The solution is to actually buy the t harness and fosgate dsp, which saves the canbus and keeps the factory wiring in place (bit late for me as I cut, solder and heat shrink every connection I made, so that'll be a fun mess to clean up)
Just thought this may be a bit of slightly useful information for those doing the factory amplifier (DSP) bypass on a 2018. I've certainly learned more about the canbus network than I planned on.
If anyone else has had this issue, or knows of a different cause or a different solution, I'm all ears. I will be reconnecting the canbus wiring first and going from there this weekend when I get a bit of time to get back on the car (has only been in the garage with no interior for a month).
