2018 Support Now Available!
COBB Tuning
Austin, TX
AT EcoBoost, MT PP EcoBoost
Giddy-upgrade your 2018 Mustang EcoBoost from pedestrian to equestrian! COBB is excited to announce support with the Accessport and full Stage 1, Stage 1 +, Stage 2 and Stage 3 Power Packages that maximize the potential for your 2018 Mustang EcoBoost! The appropriate Off The Shelf maps are included with these packages and receive a bump in power over the previous model years. Custom ECU tuning is available through a Protuner and COBB Custom Features will be available soon. Each of the COBB Staged Power Packages available are detailed here.
Kyle@COBB
Brodirt
White Plains, NY
2018 Lightning Blue Ecoboost AT PP every option.
Kyle@COBB
A couple of questions.
Can I buy stage 3 and install a down tube later? I have all other mods and even have a down tube waiting.
Can I buy 91 octane and run on 93 or vice versa? Will it change performance?
If I buy accessport and tune at the same time will the port have the tune loaded?
Do I need to keep the port installed or can I tune and uninstall?
COBB Tuning
COBB Tuning
Austin, TX
You can buy anything in any order. You just have to make sure the map you are running corresponds with the modifications you have installed. Here is a link to the map notes outlining the modification requirements for each map.
The number in the map name is the minimum octane that can be run. You can run the 91 map with 93 octane in the tank but not vice versa. This will add some detonation resistance but will not increase performance.
The Accessport comes with every off the shelf map included.
Once the ECU is flashed, the Accessport is installed to the car and the tune will remain. This will be the case until you reflash the ECU again. This does not have to stay plugged in unless you want to monitor/datalog or make changes.
Kyle@COBB
Brodirt
White Plains, NY
Kyle@COBB
I’m not sure I understand your answer to 3. Are you saying that when I buy the accessport and install it I will have all tune options to choose from? No extra fees or downloads?
Kboeh
GA
Karl
2018 Dodge Challenger Scat Pack, 2019 Mustang Ecoboost performance Pack, 1978 Pontiac Trans Am
When will 2019 support be available?
COBB Tuning
COBB Tuning
Austin, TX
That is correct.
Too early to say as of this instant. We'll know more once we get one. It certainly won't be as long of a wait as the 18 was though.
Kyle@COBB
prostovovatt
Baltimore
2018 Orange Fury Ecoboost Manual Performance Pack
Thanks, guys (finally) I've been waiting since I got my car in April ( I already have full exhaut and intercooler from CP-e)
Would I need to get custom tuned because I am not using COBB parts?
SVO MkII
IL
2018 Ecoboost, 6sp, PP, 2017 GT Convertible
Do you have dyno charts comparing the COBB tune to the 2018 stock tune?
COBB Tuning
COBB Tuning
Austin, TX
The OTS maps are made with the COBB parts so those are ideal but you can get typically get away with other manufacturer's parts on this platform. As long as you have the correct modifications, you should be fine. Check out the map notes for the details: https://cobbtuning.atlassian.net/wiki/spaces/PRS/pages/98417021/Ford+Mustang+EcoBoost+Map+Notes
Check out that blog post linked above: https://www.cobbtuning.com/2018-ford-mustang-ecoboost-support-now-available/
Kyle@COBB
BigBootyJudy
Oregon
2018 w/ AT | Oxford White w/ Black Accent Package
Kyle@COBB
Any particular reason why you guys didn't remove the 120mph limiter with this tune?
Rob0381
Kansas
Rob
2015 Mustang RS1 Premium W/PP
I don’t think they could do that without adversely affecting the car. The increased speed limiter is also a result of a larger radiator, and I believe an oil cooler, not just the ecu. Too many customers would use a Cobb tune and then blame Cobb when their car overheats at high speed :headbang:
SVO MkII
IL
I'm pretty sure the 120 mph speed limit is tire related. The Perf Pack cars have a 155 mph limit.
320guy
EB PP soon
Perf Pack also has a bigger radiator.
Kboeh
GA
Karl
At speeds of 120+ the radiator is getting so much airflow that the mildly increased size will not have much affect. It is most likely due to the tires.
Brodirt
White Plains, NY
Maybe its the demographic of the purchaser of the base model being younger, less experienced drivers?
That said, Im the owner of fully loaded PP and Id bet far older than the target market and I've not yet seen the 120 mph limit of a base model.
