TGGT
Have you experienced a problem with the balancer hub? How much of an interference fit is it supposed to be? I’m a little concerned about this as well. I suppose I will mic both surfaces prior to installI don't think I'm going to do a lick to the engine. Bounce it in the car and go for the rest of summer.
Planning to get a new damper hub from ATI and have them hone it for the tolerances of the crank I get in the long block. I'll need to get a good mic. They'll do it for $40. I'm going to add the Crank Saver Stud instead of the bolt I used (although I had no issues). Add new flex plate bolts, too.
Larger procharger pulley and belt, tone down the timing. Let'er eat off the footbrake.
