2018 mustang gt whipple issues
Any thoughts.. Still on 1st tune from whipple
  • Wrench light came on dash
    Votes: 0 0.0%
  • Throttle code aent on bama tuner
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Scott z
Cary il
Scott
2018 mustang gt manual
I need to get some feedback on whipple rune for my 2018 mustang gt with manual trans. Had the car back from install for 2 days.. Dyno only made 640 rwhp. Whipple said that the tune needs to be revised.. Wtf! So am I finding out the hard way that they are behind the learning curve??? Help me mustang people. Thanks Scott z.. S550 love!!
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
Why do you mention bama tuner in your poll? I've had a couple of revisions from whipple, but that is expected as this is a new platform. I've had no check engine, or wrench lights, and the car makes in the mid 700 range.
95civic2005
KY
Brian
I’m a little confused on the poll myself. What exactly do you mean?
I have a 2018 MT82 and it’s making close to the same numbers as yours. 628hp on a mustang dyno and 643hp on a dyno jet. According to the dealer who installs these kits and Whipple these power numbers seem to be inline with others.
I understand all dynos will read a little different but how did Whipple dyno 700hp through the 10spd auto and ours 60hp lower.
Scott z
Scott z
Cary il
Scott
I have a act tuner from before I had whipple installed, I just had it hooked up while driving yesterday to watch my fuel trim levels... I do have the tomahawk tuner the kit came with. The car was pulling timing at 6500 rpms.. It pulled 4 deg.s total by 7500.. The guy was not to sure why its pulling timing.. We called whipple and sent them data log. Don't know what's the deal.. Do you have any ideas??
95civic2005
KY
Brian
What fuel are you using? My car only seen 17 degrees of timing on the dyno they said. Still waiting for the logs tho...
Scott z
Scott z
Cary il
Scott
This is my first time on a forum like this so I'm not to sure how to start my conversation at the start with the threads etc.. Anyways, Steve from whipple said that 639 two was defiantly low for the stage 2.. From what I understand every degree of timing equils 10 hp roughly. So that would be right about where it should he without the detonation issue..
Scott z
Scott z
Cary il
Scott
Cool, I figured that this would be the case.. In very happy with the kit for sure... I m new in the sc game so to speak, so trying to get all the info I can to really see how other people are doing with the same setup.. Thank you for the response..
95civic2005
KY
Brian
I didn’t realize you were a stage 2 kit, must have missed that somewhere. I’d be on the phone with whipple getting a revision tune ASAP. Any information you can provide them with data logs will help.
Scott z
Scott z
Cary il
Scott
I am running 93 octane fuel.. I have flowmeter scavenger x pipe, and kooks mufflers.. No active exhaust.. But, I really want to go back to active.. The car is just TO LOUD now.. Has anyone had an issue with their wiring harness from the factory ? My active went out and I didn't know why until my guy took the stock mufflers off, my wires were exposed at the harness point and cauaed the electrical system to flash a short so my active exhaust stopped working. I am going to see if my dealer will warranty that harness so I can go back to my active system.
Bluelightning
Bluelightning
It will pull timing for a few
The first time I dynoed my car on the original time from them, it was pulling a bunch of timing as well. Turned out it was due to a bad tank of 93. Got better gas and all was good.
Scott z
Scott z
Cary il
Scott
Yea sorry I didnt mention the stage 2 part.. Pretty important..lol!!
Scott z
Scott z
Cary il
Scott
Yea, for sure.. Last night it went onto a limp mode of some sort and my sct tuner is giving a throttle code. I don't know if that is correct or not.. But will get to the bottom of it this week hopefully.. So no driving dark knight until she gets some love..
Scott z
Scott z
Cary il
Scott
How did you know it was bad gas???
Scott z
Scott z
Cary il
Scott
And my check engine light is now STAYING ON.. only after it puts itself into the limp mode .. I drove VERY SLOW last night about 2 miles to get it home.. It didnt pop into limp.. But something defiantly going on with it...
engineermike
La
2018 GTPP A10
Dustin posted the other day that every 1 deg timing pulled is more like 25 hp.
For throttle codes check the extension harness. Unplug it, inspect pins, plug it back in and make sure it clicks. I’ve had this problem before.
