Whipple car throttle issue
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
That video was very helpful with the magnet, thank you Burkey
Unfortunately after getting TP2 in the fully closed position & .445v and all other specs perfect, relaxed, TP1etc it made no difference. Still won’t see under 9% at idle and 87% WOT. I sent Whipple my logs last Wednesday, they emailed me Monday that they are reviewing them, called Wednesday said they are still reviewing them, emailed them yesterday for an update on anything and still nothing. Very frustrating.
Those are normal throttle angles...
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Redemption
Redemption
California
I was hoping it wasn’t normal because it would help explain why my starts are so harsh & why Im getting so much KR with my setup. 3.750 pulley, JMS BAP, 72lb injectors etc I wouldn’t think it should as soon as I go WOT in any gear/speed.
Redemption
Redemption
California
Plus Ive looked at other people’s logs and seen 0% throttle at idle and 100% WOT...
TX-Ripper
SE Texas
Throttle angle and pedal position are two different things.
Whats the run down on the car, how many miles, how long has the blower been on, who installed it, what plugs and what gap, I'm assuming the Whipple tune.
Jeg70
James
15 mustang gt
I have a 15 GT with the 3L 5g Whipple on the whipple tune with 50 state legal setup and have exactly the same quick ramp up throttle issue as well that you describe even seeing the same effect when cold was hot and I would be interested if you get it resolved with Whipple. I had loaded the tune via their tomahawk with crank relearn etc and they said to improve drive ability it may need a revised tune that requires use of a hp tuner with credits. I am following up with my performance shop to gain additional details options etc. but like you describe. Little to no throttle is ok but then all of a sudden out of vacuum into boost and without significant pedal movement throttle keeps increasing makes it super hard to even take off on wet pavement.
Redemption
Redemption
California
My issue was the IAT sensor was plugged into the wrong port. On my Gen 3 setup it goes into the grey connector on the passenger side & I had it plugged into the driver’s side. On your Gen 5 I’m not sure if it would be the same but check the instructions.
HKusp
Hampton, Md.
Jason
I saw a guy on here the other day who was dealing with Whipple and they over nighted him the new HP device with their tune on it. You should start a ticket with Whipple. They are very good to deal with via email.
RoushSTG2
Kansas
Sterling
2015 Roush Mustang Stage 2
You are absolutely correct. I just found a sheet from Whipple online about this and went outside & mine is reading 4.08 with the throttle forced closed and it looks like the throttle stop screws need to be adjusted along with the magnet. I have up to 4.5v to play with & I bet that will cure this. I will be reporting back in a bit.
I know this is an old thread but I’m at a loss here so any help would be greatly appreciated. I’ve been having the same issue with my tb and tried to do this adjustment but the magnet seems stuck and doesn’t want to rotate. Have you heard of anyone having this issue?
Redemption
Redemption
California
The magnet will definitely try to break, mine chipped a few pieces off. My issue was my own stupidity though, had nothing to do with the TB. Start a support ticket on Whipple’s website, their customer service has always been top-notch for me.
