2018+ Mustang GT Trim Question
In5am0us
New Jersey
Dylan
2020 Mustang GT Premium
I have two questions about the following 2020 mustang GT premium trims…
I’ve been told that the 401a package on the GT premium makes it heavy. What parts in it make it heavier than the other trims?
Also, what in the performance pack make the 2020 GTs faster than the nonPP?
KingKona
Virginia
Shlomo
2019 GT
I think it's mainly the heated & cooled seats that add the weight.
Everything in the Perfromance Package makes it faster. Better suspension, better brakes, better cooling, better diff, better wheels & tires, etc., etc.
In5am0us
In5am0us
New Jersey
Dylan
Isn’t the diff a 3.55? I have a 3.15 and I’m really considering making that switch if it makes a difference
KingKona
Virginia
Shlomo
2019 GT
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
The 401A package is somewhat heavier due to the added doodads and what not. The B&O Stereo, all the added electronics and so on. Its not that much heavier. The PP is only faster due to the better gearing, even that is debatable.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Performance Pack is a Torsen diff (3.55 auto, 3.73 manual). Non-PP is the trac-LOK diff.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
Yeah 10 speed auto. Does it make that big of a difference over 3.15?
I drove several mustangs when I was looking and drove 3.15 and 3.55 back to back. I searched out a car with 3.55. If you plan on going FI then the 3.15 might be what you are looking for.
ShadesOfBloo
SE Virginia
1980 Datsun 210 wagon, 1992 Nissan 240SX, 2008 Evo, 2020 Mustang GT
Also, what in the performance pack make the 2020 GTs faster than the non-PP?
EDIT: Someone has spelled out gear ratios, but...
Given the bigger tires and the extra rotating mass of the wheels & brakes, the gears probably make a tiny difference in a straight line.
The PP car should be capable of cornering better, and turning better lap times, because of
wider & grippier tires, bigger brakes, some different bushings, and the Torsen limited-slip.
In5am0us
In5am0us
New Jersey
Dylan
What does it have for better cooling
MAGS1
Mark
2022 Mustang GT
PP has larger radiator and a different belly pan that helps direct air for brake cooling.
Dave2013M3
El Segundo,Ca
you'd need to go to a "torsen" diff i think?
You don't need to do the Torsen, but it has to have the diffy from at least from a 3.31 car. However, Ford sells the Torsen rearend through Ford Performance, probably your best bet. You can add 3.73 gears to a non Torsen rearend, just has to be from a 3.31 car and above.
geezer stang
Birmingham, AL
2017 mustang gt,base
excellent explanation sir,thank you!
