engineermike
....and actuation of the electronic bypass valve.
What did you see for oil pressure with 5W-20 under the same conditions?Hey I got a 2018 Mustang GT PP1 with e85 and run 5w-30 because I run my car hard. Its getting cold were I am at. I can see oil pressures in the 100’s if I am on the gas until the oil is Significantly Warm. Still see 75-95 at 7750rpm with warm oil.
Best advice for sure. With thick enough oil and crappy enough filters and cold enough temps, you can blow the filter right off on some engines. BMW used to have (Maybe still do) a tach that would change the redline as the oil temp got warmer. I permanently have my center gauge set to oil temps and although it is a derived value, I still won't pound on it until it is warmed up. Coincidentally, oil pressures are lower as well, and going into oil filter bypass is less of an issue.Best practice is to always keep revs down until the oil is near full operating temp, regardless of oil viscosity used.
Just had the same happen this morning. Nothing like a motor oil bath on Thanksgiving Day. Can it pour out any faster or more horizontally?Thanks. I wish I had watched it closer previous to this. I was a little stressed yesterday. I had an Exxon Valdez level oil mishap during the oil change as well. Another hour and a half on cleanup and still a little oil residue on the garage floor.
I also run my center gauge that way...I permanently have my center gauge set to oil temps and although it is a derived value, I still won't pound on it until it is warmed up. Coincidentally, oil pressures are lower as well, and going into oil filter bypass is less of an issue.
Always irks me on the "cold start" exhaust videos people post. Take a cold car, start it and zing it up to 6000 RPM. Yikes. If the main bearings could talk....
