2018 Mustang 5.0 ABS draining battery?
myjaja
2018 Mustang 5.0
So I've noticed my battery draining a bit. I decided to start pulling fuses to see what's causing the drain and once I pull fuse #62, the drain goes away and my voltage starts rising up again. Fuse 62 is described as "Anti-lock brakes run-start switch" which is for the traction control. I doubt my powertrain warranty would cover repairs for this. I couldn't find any relays for the ABS. Any ideas what might be causing it stay on when the car is off?
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Try a youtube search on the subject.
Call_Me_Bruce
Stevensville, MD
Jason
2022 Mustang GT, Toyota Avalon,
I suggest a YouTube channel called Pine Hollow Auto Diagnostics. He did a video recently documenting how a late model Lincoln/Ford was draining the battery. It took him a while to diagnose which part was causing the drain. I'm not saying this video is the source of your problem, I'm suggesting that you take a look to see all the steps he went through to figure out the problem. At the very least you'll need a good wiring diagram and a lot of time and patience to diagnose. Electrical gremlins are the worst.
Bikeman315
Myrtle Beach, SC
Ira
Although it appears that you may have found an immediate cause it would be best to have a dealer look into this. These systems are complicated (most electronics are) and since there is safety involved best to leave it with the pros.
Mdtaylorjr
Houston tx
michael
2017 mustang gt
You need to get a power distribution diagram which can be as much as 10 pages long. Find the fuse that kills the draw and see if it powers anymore fuses further down the line. Then you'll have to pull each one of those individually or unplug every component on that fuse one at a time and retest. I hate doing draw test as they can take hours and the customer never wants to pay for the full time it requires.
