RalphK
- Apr 10, 2020
- Central Ca
- Ralph
- 2020 GT PP2
Besides normal, did they say what that noise was attributed to?
Nope!Besides normal, did they say what that noise was attributed to?
Funny you just happen to post this, for the first time my 2018 GT started to make a sound close to 2000-3000 RPM only (rattle noise) but its not anything crazy just you can hear it if your really listening with everything off inside the car.i was hearing something very very similar to this the other day.. i noticed it when going over a bridge and i could hear the sound bouncing off of the barricades on the side of the road..
i happened to check the oil a couple days later and noticed it was a qt low.. traveling over the same bridge after putting that qt in, engine quieted down a lot, had to go over the bridge 3 more times before i could faintly make out what i thought was the same rattle sound.
i wonder, is anyone with this rattle even just a little bit low on engine oil?
is this the 2k rattle everyone talks about?
Lots of great stuff here, particularly the oil aspect, so thank you! Someone here tried some sort of elaborate sound scope, and it was still inconclusive. The main theories thus far:I don't have this noise on my '18 or '19 and it's hard to hear on the video. From what I a think is the noise you are referring to here are a few ideas.
If the noise diminishes when warm I would think indicates clearances that decrease with the expansion due to heat, i.e. pistons/rings/valves/bearings/exhaust. It could also be from the massive number of camshafts and chains finally getting oil. That makes more sense to me or exhaust.
Have you considered getting a sound scope, like a stethoscope and try and isolate where the noise is coming from? Some folks are using thicker oil like 5-30 which Ford recommends for track use. Whipple told me to use 5w50 after the blower install which I've used with no issues for a few thousand miles.
Another thought is, any you might think I'm crazy here, the exhaust. Sometimes it is exhaust related which would also change quite a bit when warm. I'd raise the car up and closely inspect every inch of the exhaust from the engine to the bumper. Look for any loose parts or contact with metal that shouldn't be there. Also wondering if the mufflers might have some loose baffles and this sound can sound like it's closer to the engine sometimes. Again when warm it might go away.
Keep us posted. Good Luck!
I've checked many times, mine has never been low.i was hearing something very very similar to this the other day.. i noticed it when going over a bridge and i could hear the sound bouncing off of the barricades on the side of the road..
The pistons in the GT350 Voodoo are forged, which makes piston slap worse especially when the engine is cold and warming up. The pistons in the Coyote are hypereutectic and don't change dimensions as much as forged do with temperature changes.Lots of great stuff here, particularly the oil aspect, so thank you! Someone here tried some sort of elaborate sound scope, and it was still inconclusive. The main theories thus far:
-Piston slap, which, incidentally, is common on the GT350 and an actual TSB exists for it. Basically due to spray-in cylinder liners versus actual sleeves. Ford says normal and no impact to engine performance and longevity.
Hi, did removing the sound tube help with reducing the noise in cabin of the rattle?I find it a bit embarrassing to roll up on someone in a car that sounds so good from the back , yet sounds so crappy from under the hood. Well, on to remove the sound tube this weekend.
BTW, doesn't the dealer have the ability to look in their computer and see your visits to two other dealers for the same noise?
sound tube removal did nothing for meHi, did removing the sound tube help with reducing the noise in cabin of the rattle?
nope. Not a bit. I can’t tell any difference in the interior otherwise, either. Whatever the sound tube did, I was unaware of. I always have the sound system on anyway.Hi, did removing the sound tube help with reducing the noise in cabin of the rattle?
