djpheer
Same problem. Got my car weeks ago and noticed it within a couple drives. Brand New 2019 less than 200 miles. Does it under light throttle at low rpms. Goes away with more or less throttle. Wonderful.
I'll probably just ignore it. Seems like not a single person has got it fixed and it's incredibly common. I'll be more pissed at them keeping my car for weeks only to have it not be fixed.Mine is doing this as well. I have an 18 w/35k miles. Has been doing it since I bought it and I am the first owner. I haven’t noticed any changes in performance. I assumed it was the clutch. Maybe I should take it to the dealer again and push them harder.
Yes but they are aluminum which makes them prone to expanding when hot does it not ? That bulletin describes what I experience literally perfectly.^^^ The Coyote doesn't have forged pistons. Ford would have come out with a similat TSB for the Coyote by now if they know it's piston slap.
I went back to a camaro also. while they can have issues also, none of my motors sounded like anything other then a V8. It socks on one hand because I think the mustang looks better, I had an Orange Fury also, but I couldn't take the noises .Suck this still exists. I had no 2k rattle/diesel sound until about 500 miles. I'm pretty sure I didn't notice it on the test drive or even early on and probably would have. The noise at first happening only when the car was cold but then pretty much all the time in 2nd gear 2k-2600rpm or so. Drove with the windows down which drowned it out a little bit but it was still annoying.
Sold the GT to Vroom only b/c I took almost no loss on the car and bought it at $8500K off MSRP. Otherwise I would have kept it and dealt with it I guess. Didn't seem to affect how the car drove but it was annoying hearing that sound at lowish speeds. A sound that didn't sound "right" but could have been harmless. Have had my '19 Camaro SS for 1yr now and not a single issue luckily. If you're buying a manual GT, you should do your research and know what to expect beforehand.
Typically they use high an alloy that is hyperutectic. It means it doesnt expand as much as a forged alum piston.Yes but they are aluminum which makes them prone to expanding when hot does it not ? That bulletin describes what I experience literally perfectly.
How many times do you need to come on site and say the same thing? Just drive your Camaro and save your drivel for the bowtie crowd.Suck this still exists. I had no 2k rattle/diesel sound until about 500 miles. I'm pretty sure I didn't notice it on the test drive or even early on and probably would have. The noise at first happening only when the car was cold but then pretty much all the time in 2nd gear 2k-2600rpm or so. Drove with the windows down which drowned it out a little bit but it was still annoying.
