2018 gauge cluster retrofit
H@mmer
NE Georgia
2017 GT w/ Too Many Mods
Nothing to add, except Thank You. I'll be doing this eventually, and I appreciate the work everyone has put in now to figure it out!
+1
I want this in my current car, and if my plans work out and I'm able to upgrade to a '350 this year, well, I'm going to want it in that as well.
All the R&D you guys are doing to retro' this...THANK YOU!
z06psi
Evans, GA.
Andrew
The pot stirrer
Yeah this is something I will eventually want. Prices on the clusters will start to go up though.
You guys are awesome!
Just need a glass roof now. :headbang:
SoCalTim
CA
Tim
Sold : 15 GT
I'm watching ebay for a salvage yard to get one of these clusters...sooner or later one will come up...
ahl395
Allan
Damn that is awesome, great work.
p6cl
Near Cleveland OH
Ray
2016 Ford Mustang GT Convertible
Here is a little Youtube video of Cluster in action. I am able to hit the bottom right navi button and the phone comes up on the screen. Still no high beam indication in cluster. I will try to swap the other two button clusters in the steering wheel to see what happens. Still get an error in the SCCM Module when I try to program 1 of the lines of code.
https://ibb.co/gAJ9jb
z06psi
Evans, GA.
Andrew
The pot stirrer
O.k. that is fucking awesome!
Need a vacation in Hawaii?
H@mmer
NE Georgia
Wow. That's awesome!
p6cl
Near Cleveland OH
Ray
The rpm I thought I was missing is only for manual trans. The automatic shows the gear selector for the transmission instead of the digital RPM.
z06psi
Evans, GA.
Andrew
The pot stirrer
I would assume for manual trans this would be easier? I don't think the cluster ever shows what gear you are in for a manual.
p6cl
Near Cleveland OH
Ray
correct, the videos I've seen show RPM Where the gear would show in an Automatic.
zackmd1
Zack
It is cool that Drag Strip drive mode is there! Is that with 2016 ABD in the cluster for that 720-06-01 line? Does the drag strip mode seem to do anything?
z06psi
Evans, GA.
Andrew
The pot stirrer
correct, the videos I've seen show RPM Where the gear would show in an Aotomatic.
Like I said earlier. Need a trip to Hawaii to do my programming? :D
zackmd1
Zack
Also appears as though temperature, compass, and sync 3 information is displayed correctly! Big plus as I was not sure if sync 3 would integrate correctly. Now it is just down to high beam indicator and pony button...
p6cl
Near Cleveland OH
Ray
Yes I changed, played with three lines of asbuilt to disable active exhaust and get the select switch drive modes to work. When I use navigation it shows in the cluster as it should. I need to find out how to order the heated steering wheel. I cannot find it on ford parts web.
