2018 gauge cluster retrofit
zackmd1
Zack
Are there any differences in ABD between your ABS module and a 2018 ABS module? That might be the key to drive modes.
p6cl
Near Cleveland OH
Ray
2016 Ford Mustang GT Convertible
No clue, do get an error on abs. Afraid to touch that I screwed up my 2014 mustang. I will look
zackmd1
Zack
Look for differences in this line
760-02-02
This line should control drive modes as it allowed me to enable them on my base model. Since the 2018s have different drive modes this line will likely be different.
zackmd1
Zack
You could also try reprogramming this line in the cluster back to your stock IPC value
720-06-01
p6cl
Near Cleveland OH
Ray
760-02-02
Will try with forscan soon
p6cl
Near Cleveland OH
Ray
760-02-02
This has another section for abs
https://ibb.co/gg6iPb
zackmd1
Zack
Interesting.... Well programming the 15-17 ABS module is out then. You can try programming the cluster using the line I posted above but I doubt it will accept the data. If it doesn’t accept the data then it looks like a new ABS module will be required for drive modes to function.
DanMc85
The Source
New England, USA
2014 Ford Fusion Titanium AWD 2.0L
Was able to flash asbuilt today with help to 2018 LCD Cluster . Have transmission gears working, no check engine lights. For some reason my RPM gauge does not work any more, no steering wheel switch not working either.
https://ibb.co/c5T8qG
Look in 720-07-01... I forget the exact bit without looking it up, but one of them will mess with the RPM gauge if enabled. Same thing happens using a Lincoln cluster in the Fusion.
p6cl
Near Cleveland OH
Ray
If I read up on fusion forum will I find info I need. Thx
p6cl
Near Cleveland OH
Ray
zackmd1
Zack
Everything is working except rpm numbers in race mode I think, forscan gave me a beta that worked to program. Switch for pony button still nothing. Looking good. Also took off active exhaust which i dont have. Bright lights blue icon does not show up either when lights on bright headlights.
https://ibb.co/ezbmUb
https://ibb.co/geAYsw
https://ibb.co/bRPtsw
https://ibb.co/kWc7Kb
https://ibb.co/mOAuzb
https://ibb.co/kCPXkG
Nice! Changed cluster ABD to get drive modes functional?
zackmd1
Zack
High beam indicator could be another ABD issue.
p6cl
Near Cleveland OH
Ray
Yes asbuilt change only, found that I changed 720-07-01 and 02 for rpm which I changed to 2016 code.
zackmd1
Zack
Nice. Once everything gets sorted we might want to look at putting a list together of ABD lines in the cluster to watch out for such as RPM gauge, drive modes, and high beam indicator if it is indeed an ABD issue.
JeffreyDJ
Jedi
Dallas
JJ
'17 Mustang GT
Nothing to add, except Thank You. I'll be doing this eventually, and I appreciate the work everyone has put in now to figure it out!
