2018 Digital Cluster Installation Guide
Fr33kst3r
Anthony
2017 Mustang GT
Does anyone have the pinout for the 16 pin connector? I would like to test the cluster before the installation.
Fr33kst3r
Anthony
2017 Mustang GT
Here you go:
I tried this pinout using just power and ground but the cluster wont light up. Does is it need the CAN+ and CAN- to light up? I just want to be sure it works before moving forward with the installation.
buzz-dee
Germany
15 GT Premium PP
IDK, but since there’s no ACC wire going to the cluster, I assume it receives this information over the CAN BUS.
zackmd1
Zack
Cluster needs a power on command to be sent thorugh the CAN BUS.
15wile
15 GT
I have a base, non-PP, 300A 2015 GT.
If I add both Sync 3 (w/nav) and the 2018 digital cluster... will the navigation and song title information display in the cluster?
Has anyone tried doing BOTH to see?
15wile
15 GT
Yes I have done both everything works
Cool. I'll try it, then. If I can get that combined cost under $3k, anyway. Gonna have to hit up the pick a part junkyards, probably.
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
I too have the same setup (base non-pp) where I install a SYNC 3 with nav and then install the 2018 digital cluster. Can confirm that the song title info will show up and everything else like the drive modes will work.
Dragon2018GT
NC
Chris Dunnigan
2019 Mustang GT A10
Well just finished this install and Thanks to breeves everything works my fav mod even over my cobra jet intake absolutely love it!
w1ldthing
UK
Alun
Ford Mustang GT V8 (MY17)
Another UK install done but not quite dusted.
Missing Track Apps, Drive Modes and My Color at the moment.
zackmd1
Zack
First power up in a V6. Cluster is programmed for an 18 EB currently and I did not bother messing with the programming yet. Interesting that the Tach does not work but the trans works perfectly as far as I can tell. Is the tach not working a common issue for unprogrammed clusters or something new for a V6 install?
Thestangb
UAE
Ayham Kutit
Black S550
Of course it needs CAN..
Thestangb
UAE
Ayham Kutit
Black S550
Abd programming will fix it :)
Tampa, FL
2017 Mustang Eco Premium
Looking at doing this upgrade, but not sure if i want to upgrade the stereo from the Sync 3 to an aftermarket system. Can anyone confirm if the song playing still works with other systems? Mainly if you're playing the music from a USB. (Wondering about the Nav too, not that it matters as much to me)
