2018 Digital Cluster Installation Guide
d1331
NOLA
Daniel
2017 Mustang GT Premium Oxford White
If this is the wrong place to ask this question I apologize in advance maybe someone can point me in the right direction as my searchs turned up no results. My question is this. I’m purchasing a 2018 digital gauge cluster from a totaled vehicle how do I flash it and adjust the mileage? Would I do that through the forscan software after it is installed or is there a way to do it before install. I’m wanting to install in a 2017 GT Premium and have started collecting the other parts needed. Thanks.
Nic lemont
Canada
Nic
2011mustang
Thats my guess. Like I said I've never seen there be an issue with my color before.
Hey I'm new here and hoping you can help me find out if I can instal the new digital cluster in my 2011 mustang. And if it's possible what will work and why wont work?
arban
IL
2015 Mustang GT PP CO
Just going off of what ive been reading. This is uncharted territory and i wouldnt recommend unless you are very talented at programming/retrofitting stuff yourself.
arban
IL
The ford dealership can fix your mileage for you. Just make sure they dont flash the entire thing. Also if you work with Breeves here you could mail the unit to him and have him program everything correctly and he would ship it back. Id PM him if i was you. (ofc you will need to pay for this service)
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
It will not work in older mustangs then a 2015.
Mileage cannot be changed by the ford dealer. They don’t have the tools to do it. I can do it for a fee. PM if interested.
th2408au
Australia
T
Mustang GT
does anyone know which module and what settings need to be changed to display the MYColor option on the 2018 cluster, i had the MyColor option before changing the Cluster and im sure it was on the 2018 cluster when it was first installed but now its gone
th2408au
Australia
T
Mustang GT
Finally got the right part for the lower cruise control switch, now the last thing that doesn't work is the MyColor. I checked the BCMB codes and they are correct (the car has mycolor hardware), but I have extra lines that aren't covered anywhere else. Every code I find ends with 7B7-06-01. My BCMB has lines past that, 7B7-07(08, 09 and 10)-01. Any ideas? Everything else with the swap works, just can't figure out what I need to do to get MyColor to work.
2017 GT PP 401a
can you show your 7B7 setting, i have the same issue and if i compare yours and mine to one that works i might see what the issue is
theIEDmanget
Alabama
2017 S550 GT PP; 2015 F350 6.7l
;Block 1
7B701010042000002
;Block 2
7B7020100000000C1
;Block 3
7B7030101000000C3
;Block 4
7B704018500000048
;Block 5
7B705011449010022
;Block 6
7B706016400000029
;Block 7
7B7070111010101DA
;Block 8
7B7090164010A0A41
;Block 9
7B710019FFFFFFFFB66
7B71002FFFFFFCD
;Block 10
7B71101FE00CE
Didn't have a screen shot, but this is the notepad version of my BCMB. Hopefully if helps.
th2408au
Australia
T
Mustang GT
Thanks. I will try a few things and let you know what I find out. Not having the mycolor option is really starting to bother me so I need to get it working
bee bop
Temple, GA
2002 GT Vert, 2016 GT Vert
Does anyone know the values for remote start? I do not have that option in my cluster menus any more, but it still works. Just want to make sure the HVAC Setting are set correctly. According to the manual it is done through the information screen and if I remember correctly that is where I set it on my old cluster.
th2408au
Australia
T
Mustang GT
;Block 1
7B701010042000002
;Block 2
7B7020100000000C1
;Block 3
7B7030101000000C3
;Block 4
7B704018500000048
;Block 5
7B705011449010022
;Block 6
7B706016400000029
;Block 7
7B7070111010101DA
;Block 8
7B7090164010A0A41
;Block 9
7B710019FFFFFFFFB66
7B71002FFFFFFCD
;Block 10
7B71101FE00CE
im getting my cluster reset back to factor this week, once i do that i will install it and see if the mycolor comes back, if so i will send you a copy of my settings
zackmd1
Zack
Just as a heads up guys... These clusters are starting to show up on ebay. I was just able to snag JR3T-10849-JJ from a eco auto (MPH) for a SIGNIFICANT discount from the new Ford price.
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
