2017 poa5b current sensor and other codes
Paulb
Paul
1969 Mach1
Hello everyone, I have a 2017 manual coyote in a 69 fastback, it has had the pats removed , Ron Francis wiring loom
I’m getting the poa5b (generator current sensor circuit low code) that I think is setting off other codes as well eg:po390,p0394, alternator is charging at about 14.8v at the battery which is in the boot, been through all the connections, tested the current at the plugs and all seems good, alternator part no is GR3T 10300 HA , when I look up 2017 alternators it gives me a pet no of GR3Z 10346, the one I have seems to be from a 2016 year? Did the 2017 have a current sensor in the alternator ? And is that why its throwing codes?
when looking at the amps in forscan it shows as -20 amp
any help or guidance would be appreciated,
thanks Paul
ORRadtech
Atlanta, Georgia
I don't have specific help for you. However, I would be concerned with a charging voltage of 14.8V. You really should be in the 13.9V-14.2V range when charging. 14.8V would have me concerned about an over charging condition.
KingKona
Virginia
Shlomo
2019 GT
FWIW, the part number for the alternator is for an heavy-duty/extra capacity alternator.
14.8V suggests to me the OP doesn't drive the car much, and the battery is in a continuous low-charge state.
As usual, the battery may be at fault.
Paulb
Paul
1969 Mach1
Battery is only 4 mths old, optima blue top, battery Test fine, car isn’t a daily driver but even with a charger on battery it stil up in that voltage, testing the alternator wiring back to the panel is normal, I did a search on this forum and found a couple of others with the same issue but no replies on what it was
Nawsad123
Everett
Bonez
2017 Mustang GT
OP any resolution on this? Getting a similar code. Similar to your battery, mine does read about 14.8 volts after about a 45 min drive. Car is usually on a battery tender for 9/12 months of the year. Not sure if its just a sensor that needs replacing, the alternator, or something else
Nawsad123
Everett
Bonez
2017 Mustang GT
Hey just had my mechanic look at this and within 20 minutes was able to fix. There is a current generator sensor mounted on one of the power cables near the fuse box. Its a bit difficult to find, but it was unplugged causing the code to go off. Quick fix just as an fyi
ORRadtech
Atlanta, Georgia
That's the connector for the Battery Management System (BMS).
