2017 ecoboost start issue
war7j
California
Jordy
Mustang Ecoboost 2015
Hey guys,
This is my friend´s ecoboost having some issues while trying to start the car, somebody had experience anything similar? Its stock and have replaced some sensors but still having the issue.
we saw high pressure on fuel pump, replaced and issue persits.
replaced:
low Fuel Iniection Pressure Sensor
high Fuel Injection Pressure Sensor
Direct Injection High Pressure Fuel Pump for Mustang
Purge Solenoid Fuel Vapour Hose
we appreciate your help :)
Johnnybee
Canada
2018 convertible
You need air, fuel and spark to start. These should all be verified prior to throwing parts at it. In addition, you need to verify that you do not have coolant incursion into cylinders. If there is coolant loss without external leaks, it is likely going into no. 2 and 3 cylinders (they seem to be popular failure points). When it does start, are you getting plumes of thick white smoke (not vapour) out the tail pipes? This is indicative of head gasket failure.
war7j
war7j
California
Jordy
i've share your comments with my friend, since the issue happened the car hasn't run again, so there is no smoke or something
coolant levels are good. it has fuel and spark plugs were new
* I didn't view the vid, so pardon that I don't know if the car is an auto or MT82...
Check and make sure that the brake pedal (and if equipped with MT82, clutch pedal) have not lost the "bumpers". There is a TSB on this issue and if either of those are missing, it will create drivability and starting issues.
https://www.mustang6g.com/forums/th...edal-bumper-nhtsa-recall.172153/#post-3670904
Also if it has the MT82, check to make sure the clutch pedal safety switch isn't faulty - if it is, the car won't start. Clutch safety switch failure:
https://www.mustang6g.com/forums/th...s-breaking-off-solutions.165464/#post-3366792
And lastly, there is this thread that contains more links for S550 non-start issues:
https://www.mustang6g.com/forums/threads/sos-car-won’t-start-solved.174650/page-2
