Good question. I bet it COULD add to that effect but realistically what you are looking for is more exhaust related.Will the PP2 setup give the car more snap crackle and pop on decel?
I have a bone stock 15 gtpp and am considering this for my first mod.
Take them for a ride in your PP2'ed car. Gave your ride some more power and got them a present in one expenditure.Just paid for mine. Better be good... because that was the money I was going to spend on presents for my parents for the holidays :doh:
I think you need an aftermarket tune specifically for LT Headers (edit: for the headers and anything else you might have on there). The tune from the Power-packs is specific to the parts it's installed with.Will I be able to install LT headers with this? Or will I run into an issue throwing codes?
Okay so I thought I read somewhere on the forum that LT's can for the most part be run safely on a normal 91 tune. If that is correct, why would it not be possible to run them on the PP3 tune? Or is it because the PP3 is tuned in such a way that it can't handle the additional air/fuel, not enough/too little timing etc? I personally would get a specific tune...but can someone educate me?I think you need an aftermarket tune specifically for LT Headers (edit: for the headers and anything else you might have on there). The tune from the Power-packs is specific to the parts it's installed with.
Not to mention, if you're adding LT Headers, then there's likely no reason to go with the Power-Pack tunes as you're shtupping your warranty and might as well add on whatever you want and then have Lund/Beef/Livernois etc. make you a tune specific to what you have on there.The tune is designed for what exactly ford is putting into the package. No more, no less. You start adding things to it, it may more than likely throw it off. If you are putting LT on, go with a different tune that has free updates to include items you put on your car. It makes no sense to get this set up, then start adding more to it without being able to adjust the tune to take advantage or properly dial in on additional add ons.
same here, central valley ayyyyPP2 on the way.. long wait but hopefully worth it.
