TheLion
From a performance standpoint, if you look back at my Excel plots of MotoIQ's dyno's (also compared to the 5th Gen LT1 6.2L in the latest Camaro SS / 2014+ Corvette), PP2 delivers a nice broad power band that is more useful for 3.73 / 3.55 and especially 3.31 gearing on road courses / auto x.I went from PP2 to PP3 about a month ago. PP2 had a very punchy, torquey, midrange. PP3 has more of a top end rush. Pulls harder to the redline than PP2. I notice slightly better gas mileage with PP3. With PP3 I just hold my gears longer usually second and third. I have 3.31 years and manual trans. My car seems to drive more smoothly with PP3 than PP2. Recently I tried driving around in track mode. Throttle response is a little more like PP2. With a manual trans you can keep your car in the powerband so I don't feel like I gave up anything going from the 2 to the 3. I'm going to focus on chassis mods now; subframe connectors, vertical links and cradle lockout. I drive 24 miles one way to work and I enjoy driving my car every day. I've had all three power packs and the driveability has been good with all three of them.
I consider Road Course / Auto x different than Track / HDPE, which have higher average speeds. That's where PP3 would shine is on high speed tracks with the majority of it's corners higher speed sweepers, at least with the stock gearing.
PP3's gains are almost entirely in the top end past 6,400 RPM. There's good and bad about that. PP3 gives you more power than PP2 or a stock LT1 6.2L, which to me is pretty impressive considering, but there's also more heat / friction at higher RPM's that you have to deal with as well. The gen 2's rods, crank, valves, valve lift, heads and cams were set up to rev out to 7,500 RPM, but it's intake manifold was NOT as it's a modified carry over from the gen 1 coyote, they just added in those adjustable runners for low RPM fuel efficiency / better idle / emissions. So the intake manifold isn't 100% matched to the Road Runner esque guts of the 2nd gen 5.0. More or less they purposefully built in a lot of potential that isn't used in it's stock configuration. PP2 and PP3 both take advantage of that potential, but are biased for different applications.
The down side to big power top end is that to tap into that you need to keep the car higher up in the RPM range. On a road coarse, daily driving, especially auto cross, that's just not always possible. It can make the car difficult to drive in terms of tapping into all of it's potential.
That broad and stout mid-range is often more useful than a big top end but flat mid-range. PP2 is better suited for daily, auto x / road race with the stock gearing. PP3 is better suited for high speed track and roll racing.
OR if your running smaller diameter ultra light weight forged 18" wheels with low profile tires, PP3 would be better. Stock tire diameter is 27.7". But a low profile tire on a forged 18" wheel is around 25.5~26". Supposed for arguments sake it's 26" for a 18" wheel with lower profile 35 series tire.
PP2 Gearing / Speed Range chart with stock 3.73 Torsen + 27.7" Tire:
Rear Axel Ratio 3.73 Final Ratio Speed
1st Gear Ratio 3.657 13.641 43.21 MPH
2nd Gear Ratio 2.430 9.064 65.03 MPH
3rd Gear Ratio 1.686 6.289 93.73 MPH
4th Gear Ratio 1.315 4.905 120.17 MPH
5th Gear Ratio 1.000 3.730 158.03 MPH
6th Gear Ratio 0.651 2.428 242.75 MPH
PP3 Gearing / Speed Range chart with stock 3.73 Torsen + 26" Tire:
1st Gear Ratio 3.657 13.641 42.26 MPH
2nd Gear Ratio 2.430 9.064 63.60 MPH
3rd Gear Ratio 1.686 6.289 91.67 MPH
4th Gear Ratio 1.315 4.905 117.53 MPH
5th Gear Ratio 1.000 3.730 154.55 MPH
6th Gear Ratio 0.651 2.428 237.41 MPH
PP3 with a smaller diameter tire would be one fast setup for auto x / track. Less unsprung weight, lower side wall profile promotes better handling feedback, higher corner speeds, faster transitions etc. Corner after corner those hundredths and thousandths of a second add up into tens or even seconds. That's the whole concept between the R Spec GT350's carbon fiber wheels.
