lisandra
mama smurf
- Jul 3, 2015
- Puerto Rico
- lisandra
- ecoboost PP non premium
When you say factory oil separator do you mean pcv?
The PCV Valve is just a ball valve and spring, which is what most of us are used to seeing on NA engines. In the vast majority of cars that's all there is to vent the crank case back into the intake to relieve positive crank case pressure as the down strokes occur on each cylinder.When you say factory oil separator do you mean pcv?
Because Adam sells them, doesn't mean they are the best or only option. I just made a post a couple days back on these aftermarket tunes as a warning to those running a stock down pipe, the reason these aftermarket tunes are not safe unless you upgrade the down pipe is because lifting the power band in the upper rpm range causes the catalytic converter temps to exceed their maximum safe margin by over 250F! Ford Racing put out a bunch of documented data on why their tunes don't lift the upper RPM power band in the 2.0L EB for the Focust St as they were getting criticism for doing nothing in the upper range (their gains were all in the mid and low end) compared to all of the aftermarket tunes. This is just an example of how tuners, tinkerers or enthusiasts may not have considered all possible ramifications. The idea that "it works fine now or hasn't broken in the last 6,000 miles" isnt' necessarily a good indicator of long term reliability over the life of the car. Now that particular issue can be solved by upgrading the down pipe, but there are a lot of EB owners running a tune with the stock down pipe...at least until they start failing at xxxxxx miles.As far as plugs, you say not iridium which is what adam sells and I run. Name some alternatives then
Did you notice a difference with the Brisk plugs?I am running these in my 2016 EB, I replaced the factory Iridium plugs as part of my 3-phase bolt-on process to increase the 2.3L's efficiency, reliability and consistency (in making good power). The other two are as we all know the IC and then the catch can. Oil would be a fourth, but it's not a "bolt on" modification, so I didn't consider it as part of the big 3.
I'm not suggesting Adam isn't a smart guy or doesn't do outstanding work, but he doesn't know everything and may not have considered or know about alternatives, so I would be careful about using that as the reasoning. Now there's nothing wrong with Iridium plugs. What people say "better" alternatives, you have to keep in mind their reference. Better is subjective to your perspective.
In some cases, better might be longevity / reliability / low maintenance. Mass produced, factory setups, unless your into exotic models or 100k+ price points, usually are geared towards the above criteria. In other cases better might mean higher performance or higher performance at a certain price point.
Brisk RR14YS plugs use a silver electrode, which is an alternative I recommend considering (there are lots of great plugs out there, but also some not so great ones, just be sure to do a lot of research prior to). Silver has a higher resistance to oxidation than say copper, the highest conductivity and thermal transfer of any base metal, period. Silver electrodes give you the benefit of the performance of copper electrode plugs, but tend to maintain their performance throughout their life unlike copper plugs which tend to degrade in performance after just a few thousand miles (around 5k they degrade in their ability to ignite the fuel to where iridium are now performing better). Silver is also 20% less anodic than copper, meaning its corrosion is 20% less than copper under the same charge conditions.
Iridium has a much lower thermal and electrical conductivity (many times lower) than either copper or silver. It requires a more robust ignition system to generate the same spark energy. Spark energy actually does affect how the flame front propagates, the exact point in time at which it ignites and the consistency of ignition. Case in point, because silver has a much higher thermal conductivity, a more projected electrode can be used for the same heat range of plug as it sheds thermal energy better vs. iridium.
However they do have a shorter overall service life (20k to 25k according to Brisk customer service in Turbo applications). The factory iridium plugs are rated for between 30k and 45k. The price is virtually the same for a set of 4 of either. You can order them from Jegs E-bay store if you fancy pay-pal for convenience / security, directly from Brisk USA or from Americanmuscle, which is the only alternative plug they list for the 2.3L EB engines.
The advantage of silver electrode plugs result in higher AVERAGE cylinder pressures, more consistent ignition timing and better fuel efficiency (due to the other two). Again, the trade off is life span, 20~25k vs 30~45k, so almost half the life span. The other advantage is a higher resistance to knock as they are less prone to fouling issues (they will still generate a strong spark even partially fouled where iridium will not). They are well known as being one of the "plugs of choice" for hard to ignite fuels such as Nitro methane or LPG, which you would NOT use iridium plugs for.
Also their required operating voltage is notably lower, so as they wear they won't EXCEED the ignition systems capabilities. This is also advantageous as the ignition coils age and the con-formal coating the winding's begins to break down (aka the coils become leaky and stores less energy to transfer to the electrodes due to exposure to constant high temperatures from being both in the engine compartment and also the coils own internal losses from eddy currents, DC resistance etc.).
On an otherwise stock engine, it seems to be notably more responsive and smoother overall. I don't think there's much peak power gains so much as it's more consistent, which is the biggest issue with stock EB's. It's not going to be a night and day difference as with an inter cooler upgrade or a tune, however it works with these other changes to maximize fuel efficiency but also making consistent power.Did you notice a difference with the Brisk plugs?
Good to know on the PCV. I wasn't sure of the blue polymer elbow had a ball valve attached to the bottom or if there was no ball-valve period. So it appears that in the EB engines the PCV is to a degree integrated with the oil separator chamber.The factory PCV/oil separator has a ball and spring. That's what you gut to stop the smoking on the older PCV equipped models. If you remove the 90° elbow from the oil separator, it's incased within the bottom portion of that elbow.
In regards to the Brisk plugs, I've been running them too with no intentions of switching to anything else at this time. I agree with your analysis of these plugs, and so far, they've performed wonderfully.
I would add this to the list for the price (there may be other options, but this one seems to be well integrated to work with the system):
http://www.boombaracing.com/2015-ford-mustang-ecoboost-boost-operated-blow-off-valve/
For $235 that's a great addition giving you nice gains under the curve due to eliminating losses from the leaky stock Diverter Valve. According to Boomba, a MAP tuned ECU will not have issues with the change in venting to intake vs venting to atmosphere.
In this case, as with the others, the power gains aren't coming from changing more critical and sensitive items such as timing or boost, but rather from eliminating inefficiencies in the existing system architecture.
While the total is up to around $1,447 total for all of these modifications, they are again all low key items that should be relatively warranty safe, at the very least they can all quite easily be reversed even with a blown engine as they are true bolt on integrations.
I would bet my bottom dollar if we implemented items 1-6 with this being the 7th on my list, we could push this car into the 13.5~13.6 1/4 mile times consistently.
We've seen a bone stock EB Auto run a 13.6 in cooler weather, I think it was 54F in their video (look up one of Bama's you tube videos advertising their tune, they tested the stock car first with drag radials being the only modification). I don't see why an optimized EB 6 speed manual couldn't run similar or even better times if the driver is up to the task.
Throw in a Ford Racing tune as #8 for about $600 and the total is right about $2k. That would be on fast car for $28k total (I paid $26k out the door after taxes, titles etc.). Used WRX's in my area were going for 26~27K with 20 to 40k miles already on them, bone stock...granted the AWD is a nice advantage in the winter for a Daily Driver and the sedan chassis is more practical, however I think the mustang is a far better looking car and certainly has more track potential. With just a PP and summer tires it hit .98g holding in corners...thats Z-car territory.
I hear what your sayin'. They did the same thing with the GT, coming out this month, delayed to next, delayed to month after next...rinse and repeat 10x. However they actually did release the GT tune just recently. I would expect the same cycle for the 23EB and now that the GT tune is done I would expect more resources to focus on the 23EB. It will arrive eventually...if your patient. Either that or my warranty will expire first ;-), in which case I will go with an aftermarket tune and down pipe.Ford racing tune??? Yea right, good luck with that lol
I like your thinking and suggestions. I am at this point doing similar things.I'm not going to play because I can't pay $7k in cash for a new motor if it fails, at least not at this point in time. That may change in the future, but there are quite a few people out there who also want to keep their warranty.
Any of the bolt ons mentioned are not only low risk for warranty issues, but they actually decrease the risk of failure as oppose to increase the risk of failure while still providing performance improvements. They also provide a very solid and robust foundation for tunes once the warranty expires / or your in a position to soak up the worst case cost, aka an entire engine replacement.
