1st Tech pack With Trans Cooler!
TDC
Long Island
Best of luck to you! Paving the way for us Tech pack owners with our comfy A/C seats :ninja:
krt22
2016 GT350 Track Pack
2GPM is decent given the total volume is <1 gallon. Either way 2gpm is much much better than 0gpm =)
Nice work, interesting that the drain/fill plugs are NPT threaded.
CSL
WA
16 GT350
Awesome work. Way to take the bull by the horns and run with it. Can't wait to hear how your track day goes.
SVTDSM
SVTDSM
@Serpent_Stangs
Nashville area
2017 Shelby GT350R
Bravo, great job!
Were you able to see where the OEM cooler goes into the transmission?
Yes but the castings are different between tech and track pack transmissions. You can see were they would be but the inlet/outlet would have to be drilled and tapped. And I believe that would only be possible for inlet/outlet closest to the rear. The other inlet/outlet closest to the front is on the bell housing and since there is no pump inside our bell housing, there probably wouldn't be fluid behind that point.
ohtobbad
Nova Scotia
GT350R
Very nice work, I like the attention to detail.
Most would never know what you have done, without being told.
I think this will solve your cooling, enough to do some full track sessions.
Good luck, I can't wait to hear the results. I don't need one, but curious
what your costs were? ( if you don't mind saying)
_M_
Planet Earth
A Mustang
Nicely done. Looking forward to seeing real world testing results and data. What's temps supposed to be Saturday?
Tank
9/11 - Never Forget
Above the Notches
G0853
Excellent post. A method to your madness, clear photos, and detailed explanations. Good job!
+1.
SVTDSM- Good Luck testing for goal #1!
Anthony@HTM
SF
GT350 Track Pack
That's interesting, I'm sure this will help a lot. As long as the OEM location is shrouded with a passage way for air to flow through you'll be good!
SVTDSM
SVTDSM
@Serpent_Stangs
Nashville area
2017 Shelby GT350R
The pump was $189
Cooler $71
Air duct from track pack/R $80
$250 worth of an-hose, fittings, and adapters.:tsk:
About another $50 for miscellaneous aluminum, nuts, bolts, wire, and a switch.
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
Nice! Looking forward to an update after your track day. Hopefully this solves the heat issues. That's a great overall price too.
SVTDSM
SVTDSM
@Serpent_Stangs
Nashville area
2017 Shelby GT350R
Pretty cool actually. 50's on Saturday, and 60's on Sunday. I'll be tracking it both days. But even in those temps guys have reached limp mode in less than 15 minutes. So if I can complete 20 minutes and keep the temps well below the 275-280 degree mark that limp mode seems to kick in at, I'm happy.
live2ride90
Santa Cruz, Cali
Jared
2017 GT350R
Awesome work man, good luck with the track day and testing this weekend!
