16 Whipple GT Is this False Knock?
5.0Dave
Atlanta Ga
2015 Ford Mustang GT Base
Hey guys I have a 2016 Ford Mustang GT with a 2.9L Whipple. I am started monitoring my Knock Sensor on My NGUAGE, and when I am cruising 5-6 gear at a low RPM and very little throttle I am getting upwards of +5-10 of Knock. But at WOT it is in the Negative so I am Very Confused any help would be Appreciate.
1100saber
Ontario
2018 Roush Charged GT PP
I have a roush 18, but not uncommon for me to see similar knock under light loads. My tuned ecoboost F150 will also show some knock under light load.
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
If you are getting negative knock at WOT then you are good.
SheepDog
Colorado
Dax
This is normal.
SheepDog
Colorado
Dax
Yes, go WOT all the time. jk. It is a non issue. The system is designed to lean out the fuel trims at light load/cruise to improve fuel mileage. You will also see your timing advance somewhere in the neighborhood of +40 or more under these conditions. Presumably you are using premium fuel or E85? As long as you aren't seeing + knock values under WOT all is well. The knock sensors are very sensitive and lean pinging occurs at very light loads because the air/fuel mixture is so lean. Knock under load is what will grenade your motor
5.0Dave
5.0Dave
Atlanta Ga
Ok thanks, I am running 93 But in the next few weeks I will be switching to E85 Fore Innovations Triple fuel pump setup and hopefully this will help
SheepDog
Colorado
Dax
Going to corn might cover some of that up, but what I am saying is that you are chasing a problem that isn't a problem.
Wolvee
Williamsburg
2021 Shelby GT500
Aren't the new Whipples having tolerance issues right now? Could your impellers be touching the housing?
SheepDog
Colorado
Dax
Interesting. I would think if that were the case, It would only get worse as the blower spun faster, and OP states that knock is negative at WOT
