15-17 gen2 or 18+gen3
Friesian
Alberta
2015 Mustang GT
Which would be a better option for 700-800hp turbo car. A gen 2 6r80 or gen3 a10 ?
beefcake
Bethel
2018 Ford Mustang
either will work fine in all honesty at that power level,
BlackandBlue
Mustang
Gen 3 high compression=lower boost
Gen 3 bigger head bolts
Gen 3 faster transmission
Gen 3 better fuel system
Gen 3 more knock sensors
Gen 3 high redline
Gen 3 fluid damper
Gen 3 better flowing heads
Gen 2 sleeves in block
Gen 2 stronger block with sleeves
Gen 2 lower compression more forgiving
Gen 2 more reliable transmission?
Gen 2 more boosted
I think they are evenly matched.
I would go with the gen 3 because the A10 is the bees knees.
Rjames18
Houston
RJ
2018 Mustang GT A10 Orange Fury
Gen 3.
With the gen 3 at that power level you won't have to touch the trans.
That power level is very easily achievable with just a set of injectors and a bap on 93. Would suggest fuel system upgrade and e85 to be safe though.
Braski
Lancaster, PA
Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
Both have pros and cons and will give you the results your looking for. Personally I'd go 15-17 because of how cheap they can be found! If I had a 18+A10 I think I'd have to play around first NA on E85 before eventually going FI!
Boduke0220
NC
2015 GT PP
I think the 15-17 looks better but that A10 is nice. Can’t go wrong with either
gimmie11s
SoCal
Murica!
Cant go wrong with either. Both platforms support 800whp in stock form. The 6r80 is probably more comfortable at that level then the 10r.
Trust me when I say, you'll always want more so nothing stays very stock for long (even motors and transmissions).
Buy the one you can get the best deal on that is the cleanest and build from there.
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
A local Coyote specialized shop up here has gone through 3 10r80s running a twin turbo setup at about 800 hp. He told me personally that the 10 speed clutches can't handle power. At stock or near stock, 10 speed has advantages, but if you're going to go 800+ on it, it will give you grief.
ttbestas
Lithuania
2009 GT-R
interesting! here on the forum are few guys I guess running A10 in stock form on 800+ whp. Would be nice to hear more opinions on that
gimmie11s
SoCal
Murica!
The 10r80 has gone 8’s many many times.
How fast do you want to go?
Friesian
Alberta
2015 Mustang GT
If i go with the 10r80 i will definitely do clutches. 7th gear will not hold for long above 750 at the track
Wolvee
Williamsburg
2021 Shelby GT500
I'm curious what their Tq management is like with their tuning. Sounds like they just send it and blame the Trans.
HRSEPLA
Wisconsin
Sam
A Bunch
My experience has been that the McLeod clutches are absolutely needed after some time with 750+rwhp passes. (For sure)
I stay out of 7th gear when under power no matter what.
The rest of the 10R80 has been extremely impressive under alot of power and many track passes for me. I am impressed.
